centuridude    9
With some motivation from other posts that I have seen on this forum, I decide to add a fresh water-line to my engine so that I won't have to use a Fake-A-Lake anymore.
For reference, my boat is a 2009 Avalanche with a Mercruiser Black Scorpion engine. This is what I did in case others would like to make the same modification:
1) Remove the water in-take to the V-drive (which comes directly from the sea-water intake on the bottom of the boat)
2) Swapped out the elbow for a TEE (1" on all ports)
3) Added a 1"to 3/4" reducer
4) Added a 3/4" ball valve
5) Added 3/4" female garden hose adapter
All these parts were purchased from Lowes.
Although it is not shown in the pictures, there is already a ball-valve at the sea-water inlet.
To run fresh water, I do the following now:
1) Connect a garden hose and open the new 3/4" ball-valve
2) Turn on the water to the garden hose
3) Start the engine
4) Close the ball-valve at the sea-water inlet
Works like a charm! Makes running anti-freeze through it way easy.
  • Like 4
Nice work! Good looking install!
Sata3000    15
Any pointers on getting the water in take hose off? Mine is stuck
Exacto knife. Or a heat gun.
Screw driver works
Heat works
Don't cut unless you are replacing it
Most of us that work on multiple boats use a connection that's removable, so we have taken many different hoses off inboards....
Sata3000    15
Thanks for the response heat gun worked like a champ. Next question my 90 elbow will not budge. I have put a little heat just scared I might snap the threads coming out of the v drive to the elbow. Any advice?
chenige    84
heat and PB blaster
Sata3000    15
Thanks guys, sprayed PB blaster I will let it sit overnight and use alittle heat tomarrow
DjOM21    59
Stick a pipe wrench in the open end of the nipple to get some leverage and break it free. - worked for me.
centuridude    9
I couldn't get mine to budge either and almost ended up cutting it. I did apply heat with a heat gun (paint stripper). After doing do, the rubber softened up and I was able to work it off of the elbow.
Hein    63
The idea is to heat the elbow so it expands and then hopefully frees it up. But using a torch is scary because of fuel vapors. Definitely ventilate well before getting in there with an open flame. The pipe nipple in the V-drive gearbox looks pretty rusted. You could leave the elbow and add the tee to the threads where the hose was attached then shorten the hose a bit. Be careful not to restrict the flow from the inlet.
Edited by Hein
Sata3000    15
I thought about puting a T at the end of the elbow. There is no ball valve from the thru hole and figured it would be to much in that area to reach with a garden hose.
Does anyone see an issue with electrolysis or corrosion using brass and galvanized pipe together ? maybe it is not an issue since it is not sea water , not sure . hope someone can shed light on this or maybe it is a stupid question but maybe not. I ask because i have the parts and ready to do it as well.
CO Surfer    289
Here's what you're looking for: https://en.m.wikipedia.org/wiki/Galvanic_corrosion#Galvanic_series
Brass will have an index voltage of -0.4; low carbon steel (once the zinc wears off) will have an index voltage of -0.85 for a difference of .45. That high of an index voltage difference is likely to cause problems in a damp environment.
Joe B    17
I did all brass. kept the Elbow since it wouldnt budge, so removed the inlet hose (cut it off) and added my 1" 'T'.
I kept everything 1" and just use a long funnel. Have it angled since its cramped
Cut the hose. You're going to have to cut it down anyway to shorten it once you instal the T. That's what I did anyway.
