ryno726    16
I was crawling around under my FS33 and noticed a couple of chips in the gelcoat.  They almost look like there was a air pocket in the fiberglass, and the gelcoat just kind of blew out from not having any support behind it.  Has anyone seen this before?  Do you think Centurion would take care of it under warranty?
Also, Where the prop shaft comes out of the hull is odd looking as well.  I checked the motor mounts and shaft strut and nothing is loose, broken, or odd looking.  No vibrations under speed either. I'm thinking maybe they changed the shaft angle for this year and just didn't update the hull???? It's a 2015
Thanks in advance!
Edited by ryno726
Document everything well (dates you noticed the damage, etc) and take it to dealer to look at, hopefully they can get answers for you. I have not ever seen anything like that, in my opinion ....does not look right. Best course of action if taking the boat to dealer asap. Hopefully you are 1st owner
X2...document and get it to your dealer!
rhino89523    34
X3....That looks horrible
Carter13    69
Thanks in advance!
The last pic shows six definite abrasion rings on the shaft due to rubbing on the fiberglass/gel coat. My guess is you are correct in your assumption regarding upgrading the hull. Definitely contact your dealer immediately and good luck for the future fix.
ryno726    16
Thanks everyone for the responses.  I will get with Centurion right away.  As soon I saw it I was like WTF is this about?
Darkside    248
Yes i have unfortunately seen this before!  It is a fairly common issue with other manufactures.  Those are called Gel Voids!  My 2014 Malibu was riddled with them, my 2015 Malibu, had 3.
You are 100% accurate in your description!  When boats are built, the first step is spraying the exterior gel coat. Step 2 is adding fibreglass, traditionally, fiberglass is put in place, either mats and/or chop gun, then sprayed with resin and backrolled.  If there is not quite enough resin, or the person backrolling does not apply enough pressure, you get air pockets.  Then at a later point, holes in the gel.
The GOOD news is they are easy to fix, and usually an isolated thing.  So having 1 void does not mean the hull will be prone to more, it neans the person missed that one area.
The absolute best way to avoid these.... VACUUM INFUSION!   There is one wakeboat manufacturer doing this right now.... CENTURION/SUPREME!
This is a void from my 2014 24MXZ
Edited by Darkside
luluzer    50
Anybody got any pox/blisters happening? I got a small outbreak on my portside rear corner. Also, anyone got any knowledge or experience with anti-folwing? Thx in advance
Do you leave your boat in water? I have heard that it can blister in certain water, Centurion talks about that in their manual
