craig3x    3
I have a 2003 Cyclone V Drive and the V Drive light is on. The oil level is fine and it runs fine. No weird noise or anything. What else causes this light to go on?
beau t    8
does the light stay on after you get above the 1000 or 1500(?) rpm thats specified on the sticker above or below the light, The light should go off at 2PSI or higher form what i read from another site, if its not going off above 1200 rpm but you can't find anything wrong its probably the switch from what I'm reading the switch will set the light if it goes bad - makes sense but it would be nice to know for sure before buying a switch. Hopefully someone with better insight will chime in.
Edited by beau t
Maybe a bad sensor?
Check the wire connections on the sensor. I remember some people having issues with the wires becoming disconnected.
beau t    8
On 6/4/2019 at 9:09 AM, RhuntIII said:
Maybe a bad sensor?
sorry wrote switch should of put sensor thanks RUNTIII for replying
