Stretch
Help me plan a new ballast system? Or not?
Stretch    409
Hey Hey we like our boat porn but DANG!! Tone it down a bit! NICE ;)
Haha I gotta give you old folks something to look at.
so far I haven't seen another centurion on our lake, so I've gotta represent!
Edited by Stretch
RVR-RAT    269
LMAO :clap::thumbsup:
Stretch    409
Updated diagram of plans for this weekend
And future final plans for maybe a fall/winter project or something
VERY NICE!!
Once you've drilled your first thru hull, it's a piece of cake. Just plan it out carefully where you drill and mount the pumps. But especially where you drill. If you bought wiring harnesses for the switches, the wiring is very straight forward.
Thanks for the extra weight on the right side! LOL
Stretch    409
VERY NICE!!
I didn't buy the harnesses.. I found the diagram on wakemakers and it doesn't seem that outrageous. So not super worried about that I guess. Just don't want to burn up a brand new pump.
Doesn't seem terrible. Although just to be clear this diagram says run wire connecting 7 to 5 and then run off 5 to the battery power? And same with the other like connections
http://www.wakemakers.com/pre-wired-ballast-pump-switch-connector.html
They use snap locks to splice the wires. Probably the quickest and easiest way to wire your switch blocks along with the female butt connectors. Should be an easy wire job with the right tools and direction.
boatnut    230
Just and FYI, whenever I do anything on my boat in relation to wiring, and I know the factory doesn't but I butt splice the wires and then shrink wrap the whole connection
Stretch    409
Okay, now on the wake makers guide it shows a fuse in the positive line very shortly after the battery.. would I not have to do this but instead just use the 3 fuses (port starboard center) that are in the distro block under my helm? Or do I need to run a whole new 4 gauge positive from the battery?
I agree with you and do that anywhere in the bilge or engine compartment, but up under the dash... don think it's necessary and didn't bother myself. But if you can and feel it's better(obviously it is better), then why not!
My last boat, I did just that. Used existing wiring and disto block/fuse. The pump, in my opinion didn't get all the juice it should have. The wires were a smaller guage. It's really better to go new, right to the battery.
There's a common phrase used by many on this site. "Do it right the first time". "Right" is essentially the code word for "most costly and time consuming"! LOL
Oh, and the port, starboard, and centre are all likely 5amp fuses for little aerator drain pumps. Not Mack Daddy Ultra Johnson's! ALOT more draw there!
boatnut    230
My jabsco's draw 11.5 amp and they say 20 amp pre fuse, that's a fair amount of juice
Edited by boatnut
Stretch    409
Nope they are all 20 amp fuses
Edited by Stretch
Interesting... What pumps are currently in the boat?
Stretch    409
Jabsco and sprinkler valves for full aerators for drain
Those are the fuses for all your drains then and someone put the wrong fuses in them. They should only be 5amp. I believe... if I remember correctly, that the hatch fuse is for your current fill pump. Try pulling the hatch fuse and then fill your ballast.
Stretch    409
My stock ballast doesn't work remember.
Stretch    409
Either way I'll just pick up an amp kit or a couple long wires and 2 distort blocks I guess and not worry about it. Or do I need a distributor ground? Couldn't I just run 3 12 awg back to the battery negative before putting them all together.
For reversible pumps, you need a ground circuit thats of equal current capacity as the B+ side. In most scenarios like this, I use a fuse box/ground combo fed direct from the battery with 4ga. Thats amps for 4-5 reversible pumps and other accessories. Now, if the helm BUS is fed with substantial cabling, you can grab off of it and not run direct from the battery. Just note, you are adding about 20A per pump, to what ever circuit you are jumping onto. Most boats only have a 50A breaker feeding the helm.
boatnut    230
Newer boats have 100 amps up front, older boats have 50 amps
