Avy06    5
Its been a long slow start to summer here giving me a good amount of time to get my boat dialed in.
Steering Cable
Had to replace my steering cable it was a pain to turn needed 2 hands don't know how the previous owner was ok with that... he thought that was normal! Thanks to this forum I found the right cable part # SEASTAR-SSCX15420 and ordered it from Marine Parts Source and it worked great. FYI When I pulled out the old one it was a 19' version. Boat now turns with one figure,  now I have a harsh turn to STBD when I let go of the wheel so I will have to give rudder tuning a try! great post on this site about it!
Ballast
My Avy only had the factory center tank so I had my work cut out for me. I tackled the project of adding a rear setup, 2) 1100 wavemakers universal rear locker bags . I wanted it to come out like factory but better.  I started by removing the sprinkler value from the system and ran the factory pump straight to the center tank.  Next I added a new 1" through-hull across from the factory one with ball value and a tee.  I attached 2 Attwood Tsunami 1200 fill pumps for 1) Port locker 1) Starboard locker and ran 1"1/8 house to fill each. Next I drilled 4 new holes on the side rails for the drain and vent lines, 2 on each side and connected 1"1/8 hose to 2 Attwood Tsunami 1200 drain pumps .  (Ordered 40' of 1" 1/8 and used all but 2 feet!) Next I had to hook up the electrical. I traced and toned the factory wire harness. They wired the boat for rear ballast so that was nice. For reference (STBD Brown/Blue Ballast IN) (STBD Orange/blue Ballast OUT) (PORT Brown/white Ballast IN) (PORT Orange/White Ballast OUT) Next was to source the switches. Big shout out to JIM @ https://www.otrattw.net/ For help with the switches and engravings. While I had the wiring open I ran new line for future underwater lights.
Perfect Pass
Straight forward install and works great. Ordered directly from perfect pass they were great to deal with and it shipped fast!
ACME Prop
My boat came with a 537 prop which did not cut it with the new ballast @6k feet! I was only @2,200rpms at surf speed. Got a ACME 1619, pulls hard no hesitation at all. Now @3,200rpm and top speed @4,800 35mph on GPS.  BTW removing the prop was PITA and I have done it before. This one was really stuck! The trick that worked for me this time was to tighten the puller as hard as I could using a crescent wrench and holding the prop with my hand.  Then I took a propane touch and heated the hub, I properly spent 1-2min in-between each blade then turned the prop by hand and heated between the next set of blades. By the time I made it 3/4 of the way around it popped off!!!
I am currently working with FAE on an exhaust and will update everyone after my install.
Happy Surfing AVY06
Edited by Avy06
Way to get after it!  The Avy is a great boat!
Did you run your vent/overflow lines to the opposite side so they don't siphon out when you are leaning over for surfing?
Can both of the new pumps fill either rear sac?  So if you are only filling one side both pumps can fill that side?
Edited by Bigcatpt
Avy06    5
BigCappt Thanks!
The pumps are dedicated to 1 bag each, but with the 1200 gph speed and 1 1/8" hose I am @~6min fill/drain time and I am stoked with that! on my old avy it only had 3/4 hose and 800ghp pumps and they were slow...~15mins
Edited by Avy06
Avy06    5
Got my Fresh Air Exhaust in October last year, a week after I winterized and wrapped my boat. Spent last weekend putting it on.  First I used a heat gun to loosen up the factory exhaust hoses as I was replacing the stock muffler. This part was pretty straight forward. Next, I used a laser level to get my vertical center line and prop center line dialed in.  With the help of a buddy we where able to measure and cut the square tube and bolts to size with a cut off wheel. I have only been out once since the install but I'd say I am pretty stoked. Way less noise even with the muffler delete and no more carbon in the air!
Edited by Avy06
