Wflinker    0
Last summer I purchased a 2018 Fi23.   We discovered there was a leak in the Port rear ballast but could not find the issue.  The dealer I took it to found a crack in the rear ballast tank that is part of the hull.   I have not seen the crack but the estimate to repair is $1,900.    Anyone else had this problem or issue?
I'm surprised this issue isn't covered under warranty?
Did you transfer the warranty from the previous owner?
There should be a limited lifetime structural/hull warranty...
1 hour ago, Wflinker said:
It is and that’s what we are doing thanks!
Awesome. I’m glad you’re not going to have to come out of pocket for it.
