Idaho Mike
Revo 8's
Idaho Mike    29
Has anybody attempted to install the 8" speakers where the two sets of 6.5" speakers are located in the main cabin yet? I have an '09 SV240, which has two 6.5" speaker openings on the port and starboard sides right in the middle of the main cabin area. However, I've seen that this configuration is pretty ubiquitous on the Centurion lineup for years...
I'm thinking of replacing the set of 4 in the main cabin area (leaving the two 6.5's in the bow). I run all 6 off the same amp now, so wondering about amp options too.
Also, do you think a single 8" speaker would do better than two 6.5"? That seems like it might fit a bit better/easier, but if I could get two 8's that would be best.
Spec's here:
https://wetsounds.com/pages/products/REVO8_spec
Basically mounting depth goes from 3.1" for the XS-650 to 4" for the REVO8. Hole from 5" to 7.1"
I'd like to keep the use of my cup holders in that location, obviously.
Thoughts?
Edited by Idaho Mike
As long as you are driving them with a 4 or 6 chnl amp currently, no issue upgrading 2 pair from a 6.5" to an 8"
Obviously, You would not want to remove two speakers and only reinstall 1. One it leaves a hole, and 2, it does reduce the output, all be it not much. A larger speakers will naturally have greater output then a smaller speaker. It can play deeper then a smaller speaker, but that doesnt always equal an advantage in every in-boat scenario.
Dont overlook the 7" OD to a 9" OD.
Spec's here:
Thoughts?
No, 8" won't fit in factory location without major modifications and I wouldn't do one 8 over a pair of 6.5".
