chenige
2000 elite glove box
chenige    84
Can anyone tell me what kind of fasteners are between the hinge and the glovebox? Are they phillips head bolt/nut? hex head? rivet? Stainless steel?
Also if you have an old boat like mine with the pull/push cupholders in the side they are probably broken, I got new ones from Shell at Centurion for $10.50 each.
Actually I do not like the cupholders. Anyone put something else in?
Chris
enzo101mo    98
Looks like to me you have phillps wood screws and did someone change the lid? (WOOD ) By the look at your picture your hinges are not lining up, so make sure you put them in proper spot. If the holes going the deck are stripped out you maybe able use a tooth pick in the holes break it off flush with the deck and screw in your screws.
chenige    84
The plastic vinyl covered glove box lid is sitting on my kitchen table.
Screws into boat are Phillips and fine.
What I am missing and not sure what they are are the fasteners from the hinges to the lid itself.
