bluesman280    99
Looking for quick ballast advice for surfing behind my 2001 Typhoon.
What would you guys recommend for a set up with my avaialable ballast
Ballast avaialable:
Factory:
Port - 250lb
Starboard - 250 lb
Center tank- 250 lb
Sacs:
port seat - 225 lb
port locker - 800 lbs
bow - 350 lbs
spare - 350 lb ????????
Or do I just fill it all and go from there? :thumbsup:
Ballast avaialable:
Factory:
Port - 250lb
Starboard - 250 lb
Center tank- 250 lb
Sacs:
port seat - 225 lb
bow - 350 lbs
For surfing on the port side.....
Fill up factory center and factory port
800# sac in port locker
Spare 350 on back seat toward port side
port seat 225
Do not put all 350 up in the bow. It will only need 200# max weather in people or sacs.
Should be a really nice wave!
Set your perfect pass at 10.5 and then speed up in small increments until you get what you are looking for.
I'll let someone else help you out on the starboard side. I don't know anything about the dark side.... :thumbsup:
Edited by Bigcatpt
