Zheld5
What is the difference?
Zheld5    1
Hello everyone I’m new to the centurion Scene and own a 2004 elite v. My question is what is the difference in the elite v c4 and the avalanche and the avalanche c4?
The two key differences are:
Avy is 22' and change while Elite is 21' and change in length
Hull is different in 2004. Elite hull shape has a sharp cut in and then down below rub rail while the Avy is almost straight down to the bottom under the rub rail. This gives it a bigger foot print in the water which creates a bigger wake.
trim options and other small things might be different as well along with usually about $10-15K more for an Avy over an Elite. I believe 2006 is the year the Elite went to the same hull shape as the Avy but still a shorter version.
rhino89523    34
C4 on avy means wrap around seating, non C4 means walk through.
