CeeDee
Johnson vs Jabsco
CeeDee    16
Is that box with the numbers the back of the switch? And the cables with the lines are grounds?
The box is a relay. It allows straight battery voltage to go to the pump instead of through the switch.
The box with the numbers is the relay and the numbers are on the relay just like that, on the bottom by each post. The switch could have numerous wires off the back, you will have to test which one goes hot when flipping it.. Yes the hash marks that get small is indicating a chassis ground.
thanks
