We have a 2014 Centurion Enzo. We were out on the lake and noticed the touchscreen was on but none of the functions were working. We replaced the battery but it did not fix the issue. The touchscreen comes on but none of the gauges of ballast work..... We have checked all fuses, cables, pin connectors, etc. Anyone have this issue or have an idea of what could be going on????
You will most likely have to order a replacement screen. Unfortunately, this is becoming a common occurrence. As of yet, no-one has posted success in rehabbing the existing screens. As far as I know, the only way to get a new screen is to order through the dealer. You can try cleaning your screen really good, and you may be able to get it to work good enough to limp through the season. Grease and oils on the screen tend to cause the screen to think it is pressed and create non-responsiveness and ghosting where it starts changing settings on its own.
I have not delved into it, but does anyone know if our touch screens have a port for a mouse or trackpad or something? It would be nice to still be able to control the screen even if the touch pad itself went out. Would just need to click from one setting to the next and select where desired. Probably not possible, but it might be a solution for some of these 4K replacement screen issues many are having.
