Wet dreams    0
Is there a way to see how many hours are on a 2004 supreme sky 220sp direct drive.
MFaso    56
If there is no counter on the boat somewhere, normally your dealer would have something they can connect to check. Not sure exactly what and it varies by brand but they know how to check it, somehow. :)
They read the ECM, should not only tell them how many hours are on boat, but at what rpm the boat was run and for how long....so like 200hrs at 1000rpm, 300hrs at 3300rpm, etc.
I know for sure they can do this on all the newer boats, assume so on the older ones too
Getssum    10
There should be an hour meter built into the tachometer. If it is suspect or otherwise, the dealer can plug into their scan tool and pull the data as discussed above.
Wet dreams    0
Yes there's no rpm gauge in this model and I believe the hours is built into that one
Edited by Wet dreams
