Bernie    0
Hello All,
I have a stuck Water Separator filter on my 2004 Centurion Enzo 230. I have tried several filter wrenches and the screw drive threw the filter with no luck. It is getting to the point of bending the base assembly unit. My last option, besides taking it to a mechanic,  is to remove the base assembly unit and try removing the filter outside the boat or replacing the base assembly unit. In removing the assembly I will have to disconnect 3 fuel lines. One line that comes from the fuel pump. Is there anything I need to be careful about with this removal other than leaking gas? Should I expect a lot of gas to come out of the lines?
The assembly is #1 in the diagram below.
Thanks in advance for all suggestions and help.
-Bernie
