chadr
Ballast Build - 2008 Enzo SV 240 - It Begins
boatnut    230
I've never used one of those, but I am. Guessing it's similar to a cv joint clip, and those are pretty easy to put on :)
Rhale    80
I have a crimp tool you can borrow
chadr    328
Have you used them before? I may take you up on that but I have a friends Tige that we are going to do after mine. I may have it for a while. I will let you know.
Dandy    43
Spot on, pretty much just like a CV joint application. Easy to use and they work well. I did a fairly in depth (bag swap, added additional fill and drains along with a crossover pump) last spring on our previous boat. I used the crimp clamps everywhere that I had the correct size and they are hands down the way to go. Easy to use, quick installation and no sharp edges. I found clamps and tools in the lawn irrigation dept of a local home improvement store.
chadr    328
I have a friend at work that does a bunch of electrical relay coordination. He is thinking through my switches for me. He is thinking that I may burn something up if I am filling and then one side is switched to pump out either accidentally or on purpose. I hadn't thought of that before. he thinks that if this happens, we may have to isolate the aerators to where they are the only pumps that pump out instead of the Jabsco's when this happens. I think I can deal with that though!
I am glad I talked to him about this because I hadn't thought about that before.
if you are wanting to drain with both the jabscos and aerator pumps, then you would need to use some more diodes and relays to ensure only the pumps and valves you want on/open at any given time are the correct ones. I recommend since you are using the valves that you fill with the jabscos and drain with the aerators. If you want the jabscos to speed up side changes then run 1 of them in a crossover configuration instead of using as a fill pump.
Though, I'm sure you can map out with two relays in series the way to isolate the individual jabscos in case you are filling some and draining others.
Edited by volzalum
chadr    328
Anyone have tips on how to get the hose up all the way on the Barbed fittings? Do I need to use heat gun to warm the hose? I am going to be hours on this if I don't figure out a faster way!
boatnut    230
Use a little Vaseline or soap , but should not be stupid hard
I always used hair spray. It was slippery when wet and had some adhesion when dry.
boatnut    230
Yup that too, great for handlebar grips
chadr    328
Just found this! Heat gun!
chadr    328
Anyone know of a decent buy on check valves? They are pricy!!! Wakemakers brand are $16 each!
surf moocher    127
Yep, that's what I used, heat guns rule, just don't set it down on your vinyl after your done :p
  • Like 5
boatnut    230
Ouch!!!!
Heat gun and a little dish soap.
  • Like 3
BHenson    3
Guys, I don't understand something here? With the sprinkler head system, each tank has its own discharge pump to empty each tank, or bag. Why not just add a separate aerator pump to fill for each sack? Thats how I did mine and I love it. I have 7 sacks total including the 2 bow sacks. I used a 1100 gph piranha pumps. 1 for the 2 bow sacks, which already had 2 factory discharge pumps. And 5 1100 gph piranha pumps for the 5 sacks I have in the main boat. Only added 1 extra switch. Works fast. Heck the pumps are only $54.00. Not sure why the complication of this install? Tell me what I am missing here?
BTW use the sprinkler head wiring to operate the relays for each pump.
Edited by BHenson
The typical aerator pump has to be placed lower in the boat than the impeller pumps. Additionally, the aerator pumps allow water to drain back through them. The use of the relays, pumps, and valves allows switch control to combine multiple fill,pumps to speed up the process.
chadr    328
The main reason that I am working it this way is that I am able to utilize the pumps that are already in my boat and don't have to buy new!
My main goal is to eliminate the restrictions of the existing sprinkler valves and install the ball valves in their place with a more free flowing system that utilizes both pumps at once to fill. I don't want to completely redesign the system because I actually think it has potential. I just think they didn't think of the surfing becoming this big in 2008 when my boat was built.
BHenson    3
OK, just didn't quite understand. Like I said, I put the 1100 gph pumps in and it fills in less than 10 minutes, and the pumps cost the same as those valves. It was pretty simple. But good luck with it. Hope it works out for you. Looks like a cool idea.
N8 Froelich    12
Hey Chadr,
I've got an 11' Enzo and it's a new boat to us so I'm pretty reluctant to tear up the factory wiring, especially because I believe the current system is powered by a sealed power module. That said the sprinkler valves are a pretty big restriction to the speed of the system. Based on all my research I had not seen a valve like you've found here and neither had others in similar threads. They were either 110V or they weren't NC, or they cost about $200 each, or they were the size of a grapefruit. Is this a new find based on your experience?
In your opinion would these make a good direct replacement for the sprinkler valves? I see the chatter about the relays but I'm thinking that is because you're doing additional pumps and going multi-directional. I'd just be sticking with the with the single pump and stock wiring. I'm guessing these valves need a constant power, and a dedicated ground to charge the capacitor and then the valve is controlled by closing to ground?
I'm really just looking for small time gains and more reliability over the sprinkler valves.
Thanks if you have time.
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
