CrewAdmin
CREW DEAL: 2015 DECKadence Marine Flooring
CrewAdmin    192
What is DECKadence Marine Flooring?
DECKadence Marine Flooring is the finest alternative to traditional snap in carpet available.
Specifically designed for the marine industry, this durable product is extremely comfortable to walk on and the anti-microbial ingredient within the product prevents mildew and associated odours. The half inch thick coated fibres will repel most liquids from engine oil and fish guts to red wine and coffee so staining is a thing of the past. This “flow-through” material has a patented non-slip backing which allows it fit snug from one side of the boat to the other with no need to snap in. To clean; simply hose or power wash. For tracked in oily kinds of residue, you may need to spray some degreaser and rub with your deck brush first. Clean right in place on your boat!
If you stand at the helm for long periods, you will definitely appreciate the anti-fatigue, cushioning effect of this product. It absorbs shock and is very good for your SOLE!
DECKadence Marine Flooring is manufactured to a standard 14mm thickness providing comfort along with an anti-fatigue feel beneath your feet and is available in a variety of colours to compliment your boats’ colour scheme.
Brand your marine flooring with your boat name, business name or family name or logo. Our printing studio will customize your choice of colour with a message that greets your guests as they come on board. Add borders around the perimeter of the material to compliment the colour scheme you have chosen for your boat. DMF is truly a product that can be dressed up for the occasion and image you are trying to portray.
All boats will benefit from DECKadence on the floor. Safety and comfort are important, so you (and your dogs and kids) will appreciate the non-slip aspect on both the decks and swim platforms.
Quality boat builders such as Mastercraft, Malibu, Tige, Campion and Centurian to name a few have included DECKadence as part of their offering for new boats. They understand the customer demand for a suitable and practical solution to the problems often associated with marine carpet. We are so confident in our DMF product that we confidently provide it with a 5 year warranty. In all likelihood it will perform well for 20 years.
As a boat lover, we ask you to create a check list for all the difficulties you experience with marine carpet and compare it to DECKadence Marine Flooring – the choice of boat owners. Finally………a solution!
What wrong with old fashion boat carpet?
Carpet is fine in the cabin but is not the best outside in the weather. It mildews, wears out quickly, retains water so is always soggy in inclement weather, stains and smells! All of which DECKadence does not do.
Since DECKadence will last as long as you own your boat, although it is a premium product and more costly than carpet, you will never need to replace it or spend money on cleaning it so ultimately is it much less costly than carpet! At 1/2"/14mm thick it is double the thickness of carpet so it is extremely comfortable.
How is it installed?
Installation is not TECHNICALLY the right word.
Since it is more than three times heavier per sq ft than traditional carpet it lays flat. The patented backing prevents movement on your gel coat and since it is flow-through (vs solid backed), it cannot catch wind under it and blow away. We also do not require snaps other than on stairs and swim platforms for safety reasons. The DECKadence mat is sized/cut differently than snap in carpet which requires all pieces to be snapped in place so the carpet won’t move or blow away. Also with snap in carpet there is usually a gap between the edge of the carpet and the walls generally provided which traps and holds dirt in most cases. On carpet the gaps are for air to circulate and water to drain away in the hopes that the carpet will dry sooner and not mildew too much. Neither of these requirements are required with DECKadence and is the reason the existing snap-in carpet cannot be used as template. The DECKadence mat would not fit as nicely as it could fit and would not come all the way to the seat base as shown below.
DECKadence does not bind the edges of mats, the material will NOT unravel so binding is not required. The outer edges are cut at an angle so that “installation” is nice and clean looking like wall to wall carpet which also further prevents movement.
Hatches and ski lockers are also handled differently. Rather than having many little pieces of carpet to trap and hold dirt in the gaps. Instead DECKadence is sliced around the profile of the hatch except the side of the hinges so when it is “flopped” back down the seam becomes virtually invisible.
FAQ - Frequently Ask Questions
QUESTION: Does water flow through it?
ANSWER: Water flows through, drains away and the mat dries super fast.
QUESTION: My boat deck is slick will this help?
ANSWER: The upper surface prevents slipping and the under surface sticks to deck.
QUESTION: Will it make a difference when standing for long periods?
ANSWER: Anti-fatigue design absorbs vibration and diminishes inboard engine noise. The extra plush thickness and texture feels great on bare feet and is more ergonomic than standard carpet.
QUESTION: What is anti-microbial?
ANSWER: It prevents growth of microorganisms, fungus and mold. Eliminates rot and odor.
QUESTION: How do the pads hold up in the sun?
ANSWER: Since all pads are UV-resistant you can choose from an array of colors that last, even in direct sunlight.
QUESTION: Is the pad hard to clean?
ANSWER: The pads resists stains from dirt, fish, and even red wine. Sand and dirt pass through so the top surface remains clean. Soap and bleach friendly making it easy to clean.
QUESTION: How hard is it to install?
ANSWER: There are no adhesives or snaps required, the pad is cut to fit your boat, simply lay the pad on the floor and you are done.
QUESTION: How does it look compared to carpet?
ANSWER: DECKadence enhances the look of any deck surface on a boat, giving it a sharp, stylish and sleek look.
The CREW DEAL!
We have negotiated a special Crew Deal directly with DECKadence Marine Flooring for Centurion Crew Members. Please read all information below and PM the CrewAdmin with the required information for a quote.
Crew Deal covers all Centurion and Supreme Boat Models.
  • Mat Options:
    Mats can be ordered with several options as follows and the main/cockpit pad as well as the cooler and bow foot well pad when applicable:
    ^^^One solid mat color^^^
    ^^^One solid mat color with logo in second color^^^
    Mat Colors:
    Mats can be ordered in the following colors:
    LUNA SILVER
    DECK GREY
    GRAPHITE
    KHAKI
    Requesting Quote/Ordering:
    To receive a Quote for pricing or to place an Order for a DECKadence Mat members must provide the follow information in a PM to the CrewAdmin. Shipping must be calculated on an individual basis per member quote, we will respond as quickly as possible, please be patient.
    Name:
    Current Email Address:
    Address for Shipping:
    Phone Number:
    Boat:
    Year:
    Model:
    Mat Option:
    include one of the following
  • Solid Color
  • Solid Color with Logo
Mat Color: include one of the following
  • Luna Silver
  • Deck Grey
  • Graphite
  • Khaki
Mat Secondary/Design Color: include one of the following
  • Black
  • Grey
  • Blue
  • Red
  • Green
  • Yellow
EXAMPLE:
Current Email Address: john.smith@email.com
1234 Jones Road
Rockwell, NC 32432
Phone Number: 111.222.3333
Boat: Centurion
Year: 2007
Model: Enzo
Mat Option: Solid Color with Logo
Mat Color: Luna Silver
Mat Secondary/Design Color: Black
Note:
Pricing will NOT be sent without the required information outlined above.
Shipping:
Depending on location shipping rates should be $50 to $100, the actual shipping cost will be included in the quote.
Post any questions and we will do our best to answer them on the same day.
The 2015 Crew Deal is LIVE! Please read the entire post and follow directions before requesting quote. We are still working out pricing for some options but, most pricing is available and we expect all pricing to be available by end of next week.
Excellent work admin! I'll be picking my new boat very soon and if it doesn't have Deckadence, I'll be joining in on the deal!
THANK YOU ADMIN! PM SENT! :surfing2:
X2
X3
Praesto    25
Thanks admin PM sent!!!
Wow how could you ruin the X sequence... your post should have started with x7 :2guns:
Sata3000    15
Wow how could you ruin the X sequence... your post should have started with :2guns:
X7
tntwescott    1
Admin,
I forgot to ask this earlier , but does this deal come with the cooler pad, bow foot well pad and a walk through transom pad if applicable??
Thanks in advance,
TNT
surf moocher    127
Mr Admin, when should we expect to receive a quote? Thank you sir!
Praesto    25
Admin,
Thanks in advance,
TNT
  • Mat Options:
I don't see how the cooler pad will stay in place, unless it comes with snaps or something.
ssgviper    7
Do we need to make a template for our boat or do they have templates for our boats? I have a 06 Elite V.
Thanks!
Edited by ssgviper
Praesto    25
I know this may not add TOO much value, but I read somewhere on here that it does stay in place. So either it has snaps or it is heavy enough, don't exactly remember which one it was.
CrewAdmin    192
The bow foot well pad will stay in place without any issues that we have seen. The cooler pad will stay in place but, for it not to move at all you will need to either use two sided tape, add female adhesive snaps to match the male snaps on cooler lid or a permanent style snap that mounts through the pad with a cap on top and female snap on the bottom. DECKadence does not supply or install snaps since they have no control over where the cooler lid snaps where installed.
CrewAdmin    192
Sorry for the delay in answering this question, we wanted to have the definitive answer. Since there has been a second inquiry we will explain what we know at this point and follow up when we get the rest of the information. There are two different floor plans for the Elite-V as shown below in the image. DECKadence shows to have a pattern for a 2005 Elite-V and 2013 Elite-V. We know the pattern for 2013 will cover all Elite-V C4 models 2005/2006 and newer. We are waiting to find out whether the 2005 pattern is the newer version on right or older version 2005/2006 and Older on the left.
