Hendo    11
Hey crew. Last few times out i thought my wave wasnt as good. Last weekend i left both quick fills "full" and put it on trailer. Hit empty and only starboard had water. Where do i start?
demo9asx    23
Most likely your port side quick fill valve is stuck at the closed position. Get a flash light and get someone to open/close the port side valve. Try to open them manually with the allen key provided and spray some silicone grease. If that does not work, you will need a new valve. It's about $100 from drainmaster.
Perfect info above. Since I began lurbricating mine every third time out, I haven't had any issues.
D3 Boats    19
X2...It is a pretty simple device. Not a whole lot of trouble shooting involved.
D3Boats
SurfDad87    0
I am experiencing the same issue. This is great advice, thank you x3.
If in fact I do need to replace the drain master, any tips?
I found A picture of the part here https://drainmaster.com/rv/
which has helped me a lot understanding the gate, In my head I had something completely different about how it works.
thanks again!!
thanks again!!
replace them with the valterra style not drainmaster.  the drainmasters are garbage. search the forum for valterra.
Centurion sells a replacement kit for the Valterra valves. Has anyone used this kit? Were all the parts like the longer hoses and clamps included?
I have two brand new Drainmaster replacement valves for sale if anyone is interested.
Kiwi042    4
The Valterra valves are much better than the Drainmaster.  Much easier to open manually and have been less maintenance IMO.
