dremmick
2002 hurricane ballast help
dremmick    0
I need some help with my surf setup. My current setup is center 250 full 750 in rear port locker 400 on rear port seat and 400 on front port seat. trim tab set at 20% and speed set at 9.4 (will verify with gps on phone).. My problem is i get a very washy wake and a big rooster tail right behind the boat. Also the wakes pocket is very small and i have a hard time staying in it with my IS and shred stixx. I need a few pointers to correct my issues.
enzo on LI    79
I think going faster would help first and foremost. Maybe 10.5 to start. That being said let us know which boat and how many peeps...how deep is your surf pond as that can have effect too
dremmick    0
I had 3 people two on port rear one on front port and driver. My surf pont varies from 20-90ft
Audionly101    39
You need some bow weight and to bump up the speed a bit. Try 200-300# up front on the surf side. After that you will want to toy with some adjustments on your trim tab.
dremmick    0
I have 400 in the bow on the port side. I'm tempted to try the trim tab fin mod.
Does the 750 fill the compartment completely or would a 1100 be better
