dubbwelsh    0
Took my new-to-me 05 Centurion Elite C4 on its maiden voyage today. Everything all good except I have no speedo and the steeringwheel (rudder) seems to be 90 deg off to the port side (pulls starboard when positioned straight). I guess my question is, what are some things or logical steps to troubleshoot speedo now that its in my driveway AND can a guy align the rudder and wheel pretty easily? I'm no stranger to the wrenches, just looking for some "check this first" advice before I get to tearing into it, I'd like to get back on the lake fully working ASAP! Thanks in advance! (originally posted in general, but realized post belonged here)
CeeDee    16
Not sure on your speedo but as for the steering wheel. Under the helm where the steering cable attaches you should be able to undo the four bolts holding it on and just shift it over one tooth. Mine was off when I changed my steering cable, didn't get it on in the same spot.
dubbwelsh    0
Thanks CeeDee. It weird though, when I line up the rudder straight, the wheel is straight (trailered), but underway its not. Side note: when reversing the boat pulls starboard (90% of the time) even when wheel is turned or turning, from center to port, so reversing to starboard is fine, but when I want to go portside I still seem to spin to the left. Is this just of symptom of me being a green when navigating a sterndrive? Never seemed to have a problem swinging stern when reversing on any I/Os I've run on the lake.
Kevin Baugh    78
That's not strange the torque of the prop and the tuning of the rudder can require that the rudder not be straight
for the boat to go straight.
"when reversing the boat pulls starboard (90% of the time) even when wheel is turned or turning, from center to port, so reversing to starboard is fine, but when I want to go portside I still seem to spin to the left"
This is the way a V drive or Direct drive work nothing odd about that at all... it just requires some advanced planning when docking etc
Edited by Kevin Baugh
Kevin's right. And if you want to align your steering wheel, I wouldn't crack the helm. I'd take the wrenches with me. Get it going straight. Power down (without moving the wheel). Pop the steering wheel off, and put it back on straight. But this is loaded. If you set the wheel straight up on plane, it won't be straight at idle, etc. So pick your favorite one.
And yes, imagine the propeller as a little paddlewheel trying to move the rear end of your boat to the starboard side while in reverse. And the same happens going forward, but there's a rudder directing the cylinder of thrust from the propeller.
Make sense?
dubbwelsh    0
Thanks all. It makes sense, just wanted to make sure it was an experience thing not a mechanical one!
Skibumm    184
Your speedo I am guessing is either diconnected or clogged. . IF you look on the back you will see a speedo pick up. Attached to that is a rubber tube that goes up to the speedo. They are very easy to clog. First check to see if the rubber hose is attacvhed at both the pick up and the back of the speedometer.if they are both connected then you will need to see if anything is in the pick up hole if there is nothing you can see then pull off the rubber tube and also the one on the back of the speedo and hit it with the air compressor. Attach it back to the pick up and hit it again with the compressor. Put the compressor on the speedometer side and force it back out the way i came in.
Edited by Skibumm
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
