DaveB    5
Last season my boat started to heat up a bit at idle, so over the winter I replaced the impeller, although it looked pretty much perfect. Anyway now still have the same problem at idle it will go up to over 200 and once you rev it up a bit it cools right back down. Thought maybe it was the belt so I tightened it up but that didn't change anything. I guess the next thing might be the thermostat but not sure what else. Its a 2005 avalanche black scorpion
sounds like you are getting cavitation in the pump from a worn rear section of the pump housing. Mercruiser is aware of the problem and has come out with an update kit that replaces the back half of the pump so the impeller wears on a stainless backing plate instead of the bronze or plastic units.
Did you check the transcooler T after the pump when you replaced the impeller? There may be debrie in there slowing the circulation at idle...
DaveB    5
I'll take a look at that, I even removed the hose up at the water pump just to see how much water is being pumped and at idle there was next to nothing, once you rev it up a bit it seems to pump fine.
$5 on red......
Lets see if I gambled right.
DaveB    5
If that's it i'll gladly give you the 5 bucks but you'll have to take canadian monopoly money
Deal! :thumbsup:
Check your filter on the tranny cooler. I'm 3/3 heating up over 175 only to check and find junk in that filter.
I'm feeling lucky....
:thumbsup:
DaveB    5
Hope your right thanks I'll check it out
As much as I dislike encouraging Dura...
I think he's right.
I think he's right.
Actually True had this one... I don't mind encouraging him.
Right on True! KORITFW!
LMFAOROTF!
:thumbsup:
Edited by duramat
DaveB    5
Hate to say it but not the problem only a tiny little piece of crap in there. I would have gladly given Duramat the 5 bucks.
PayCheck    20
Did you not try the update kit like H recommended? If mercruiser has an update kit and is aware of the problem, it would make sense there be a problem there.
DaveB    5
Im going to talk to the merc guy tomorrow and try and get that upgrade. Does anyone know if there is any type of filter in the v-drive because I tried taking the outlet hose off the v drive (pump side ) and stuffed a garden hose down that and ran it and the temperature remained a constant 170 ish.
You could have sucked up some debris from the lake that is lodged in the v-drive. It has an internal heat exchanger with a course screen. This is super common if your lake has "spring runoff" with lots of floaty sticks and leaves and crap. You could put your hose in the pump side of the v-drive and see if you can flush it back out the intake grate on the bottom of the hull.
DaveB    5
If I pulled the top off the v drive is anything accessable from there
Oh don't do that. Just flush it from the pump side to the thru-hull side. You could take the hose off on both sides. But cracking the lid on your v-drive seems like overkill.
Pildo    6
I am having the same problem. Mercruiser said I may have a impeller a little shorter than it should be. I'm going to take it back out and compare it to last years impeller. If this is the case they recommended an aftermarket impeller
tuneman    6
I have this issue too. Temp is just over 175 (~180) and stays there. 2005 350 Mag MPI. It's been that way since I bought the boat last year. It's got a new impeller, clean transcooler and a new thermostat. I haven't checked the V-drive plumbing, but the temperature holds constant. You'd think that if there were blockage, the temperature would fluctuate. Could the water circulation pump have anything to do with it?
DaveB    5
I compared my impeller with the one I took out cause my mercruiser dealer told me about the shorter impellers that mercruiser made, so I waited for him to get the longer ones in, the one I took out and the new one were identical. I am going to check on the upgraded pump plate today and then the only thing left is the circulation pump, but I have my doubts it is an issue cause it spinns fine no bad bearing and it doesn't leak or make any of those weird noises that a bad pump makes.
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
