Spud
Rev 10
Spud    7
So which one would you use :unknw: ? These were both pre wired in there, I have an idea, but just confirming.
Edited by Spud
Stick a junk speaker on one set, go to where u mount your amp and the speaker wire is. Take one wire and put it on the ground of a dewalt or any type of 7-14.4 volt drill battery, then tap the other wire to positive. The speaker will pop if it's the right wire... There are other ways to test but this is the fastest and easiest... I really don't know other than guessing which is the right wire for those towers, so I would test pop a junk speaker...
Spud    7
Well, they are not connected to anything, they are spooled and zip tied at floor. I am assuming match up the red/blk with rev 10's tens red/blk and 86 the clear wire.?. It's same guage as rev 10's, I just don't know why Centurion would run both.
Btw spud it won't blow the speakers doing this. I've used the same factory speaker out of a car for doing this for 6 years, and also use to test to make sure speaker wires are still live on non working speakers that come in and it plays fine . Any old speaker will work....
It could be for tower lights and speakers, you just don't know which. Or a number of things.. I would test the wire first to make sure.. I would assume also to use the real speaker wire first ( the clear with copper and silver)... The red and black I assume is hot and ground for tower light or neons since they are set up for WETSOUNDS now... I'm guessing and trying to help without being there bro...
Spud    7
Ight, thanks bro.
Hook a speaker up to the clear wire and let it hang. Go inside and unzip tie the wires and hit each one on the battery till it pops. That's your run for that speaker. Mark it.. Move The speaker to the other side and repeat... ;-)
The clear shielded wires are the speaker wires, the red and white are for tower lights. The clear wires should be stubbed out an bundled up in the gunwale just below where they come through the deck from the tower. From there, you will probably need to extend them over to your amp.
If in doubt, use a DVOM to check for continuity.
Spud    7
Cool thanks guys, glad I asked. Been a fun project so far. Post pics when done for sure!
There ya go spud my guess was right on the clear... :-) lol
If you don't have a dvom which most regular folk don't, my way will work perfectly fine and there is nothing wrong with it...
Good deal brother!! Can't wait for the pics!!
2nd clear is for speakers other is for lights
smitty    0
I used those to pull in new ones that were the legnth I needed so I didn't have to splice them together. Not necesary but oh well..
Spud    7
Yep, all good! the wires coming from 10's confused me.
Yes clear is for speakers, red/blk is for lights or other acc....If you noticed the clear is much more stranded than the red/blk....IMO...The wire they run in junk. I would buy some quality wire and pull it through...I would use 12 ga if you can fit it, it may be a little over kill but its good, if the holes are too small step down to 14ga....That crap they put in the tower corroded and turned green in a matter of months on my boat....Kinda crazy, fresh water, encased wire, and inside the tower...after speakers started having less quality thats what i found.....
Also make sure you sauder and shrink wrap wires...will make for much better sound and longevity
The thick red (+) and black (-) are the speaker wires on the rev10's the other 4 thin wires are for the RGB LED's spud... It's in the manual..
Spud    7
Jax thanks. I have them plugged and shrunk wrapped over that. Next fall I am taking the tower off to powder coat it, I really hate that finish it as it collects everything it comes in contact with, so I will rewire all the speakers.
Kaotik, thanks as well. I read the manual believe it or not, I'm even the guy who reads the new vehicle manual as well. My main concern was I was not sure if Centurion threw the red and blk in because they knew they were going to Wet Sounds. Just wanted to be 100% sure.
Today I continue on !
SSSWWWEEeTTT spud :-) you have any more problems pm me and we can exchange numbers if something comes up your not sure of...
Spud    7
Awesome thank you !
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
