CrewAdmin
CREW DEAL: 2013 Fly High/ProX Series Products
CrewAdmin    192
All Pro X Series Fat Sacs™ are constructed with a white water rafting material called Valmex. These sacs are unbelievably durable and no longer need the support of an outer shell. The Quick Connect Valve system makes filling and draining an easy task. Furthermore, the placement of the valve holes make it possible to create the perfect automatic integrated ballast system by purchasing the fittings for them separately. All Pro X Series Fat Sac™ are available in assorted colors (Yellow, Red, Blue, Black and Gray) so you can customize the look of your system. Imagine how tough a white water raft has to be when it is slamming into sharp rocks while being exposed to the water and hot sun. These rafts bounce off these jagged rocks and Flyhigh Fat Sacs™ are constructed in the same way. One thing about Fat Sacs™ is that it does not matter if they are the exact same size and shape as the compartment or space they are going in because they will conform. If you want to get the maximum potential weight out of a space or compartment, it is best to get a Fat Sac™ that is at least as big or bigger than the space or compartment that it is going into, so it can fill up the whole area. Another great feature is the user friendly quick connect cap and chain that allows you to get the Tsunami Pump off and on quickly and easily with the cap hooked to the chain so that it will not go missing. The Tsunami Pump is fast, you simply put the pump in the water outside the boat, attach the other end to the quick connect on the Fat Sac™, and plug it into a cigarette lighter accessory plug. Your Fat Sacs™ will be filled in minutes and you will be ready to ride! When finished, simply attach the Tsunami Pump to the Fat Sac™ quick connect, put the end of the hose outside the boat, plug it into a cigarette lighter accessory plug, push down on pump into the Fat Sac™ to create a prime, and the Tsunami Pump will empty the Fat Sac™ in minutes. In addition, you can buy custom fittings for automatic/integrated ballast systems.
prox.jpg >>>Click HERE for More detail<<<
W701 - PRO X SERIES V-DRIVE SAC (SET) - 16 X 16 X 42 - 400 LBS. (EACH)
W702 - PRO X SERIES FAT BRICK - 16 X 16 X 16 - 155 LBS.
W703 - PRO X SERIES SIDE SAC (SET) - 12 X 12 X 48 - 260 LBS. (EACH)
W704 - PRO X SERIES TUBE SAC - 10 X 16 X 62 - 370 LBS.
W705 - PRO X SERIES REAR SEAT BOTTOM - 12 X 26 X 62 - 650 LBS.
W706 - PRO X SERIES OPEN BOW TRIANGLE (FITS IN OPEN BOW) - 54 X 54 X 54 X 12 - 1000 LBS.
W707 - PRO X SERIES FAT SAC - 20 X 20 X 50 - 750 LBS.
W710 - PRO X SERIES FAT SEAT (FITS INBOARD BOATS W/REMOVABLE REAR SEAT) - 1500 LBS.
W711 - PRO X SERIES INTEGRATED BOW SAC - body 20 X 29 X 12, arms 32 X 12 X 12 - 650 LBS.
W712 - PRO X SERIES ENZO SAC - body 30 X 25 X 26, arm 72 X 25 X 12 - 1450 LBS.
W713 - PRO X SERIES V-DRIVE WAKE SURF SAC - 400 LBS.
W718 - PRO X SERIES INBOARD DIRECT DRIVE WAKE SURF SAC - 20 X 20 X 60 - 1000 LBS.
W719 - PRO X SERIES JUMBO V-DRIVE SURF SAC - 50 X 24 X 24 - 1100 LBS.
W841 - PRO X SERIES REAR GRAVITY GAMES SAC - 42 X 19X 19 - 565 LBS.
W842 - PRO X SERIES CENTER GRAVITY GAMES SAC - 88 X 19X 19 - 535 LBS.
W507-C - CUSTOM SAC - Please contact CrewAdmin for help with any Custom Sacs
fit.jpg>>>Click HERE for More detail<<<
pumps.jpg>>>Click HERE for More detail<<<
W709 - PRO X SERIES TSUNAMI PUMP - 1200 Gallons Per Hour
W610-P - JABSCO METAL BALLAST PUPPY PUMP - The Jabsco Wakeboard Ballast Puppy is designed to pump water into Wakeboard Liquid Ballast Tanks and when reversed will also pump water out of them. It has a flow rate of 540 gallons per hour, so it can fill most ballast tanks in about five minutes. It is equipped with a Run-Dry Protection Device to automatically shut-off the pump and protect the impeller from run-dry damage should the pump be mistakenly left on after the Ballast Tank is empty. The Ballast Puppy also features ignition protetion which allows the use of this pump in the engine compartment. Pump. This is the same pump used to fill and drain OEM ballast sytems in Centurion Boats.
hose.jpg>>>Click HERE for More detail<<<
558031-HOSE - 1" black hose - This is the same 1" hose used in most factory wakeboard ballast systems. The solid black design creates a clean install that looks like it came from the factory. This hose is constructed with thick vinyl walls for excellent resilence, resistance to collapse and durability when exposed to bilge fluids and high temperatures. An internal helix reinforcement prevents kinking during tight bends for more installation options without limiting flow.
558031-CLAMP - 316 ss worm-drive hose clamp - Trust these clamps for secure hose connections. Constructed of 316 stainless steel for ultimate corrosion resistance. The smooth, unperforated band surface and rolled edges prevent hose damage. Band and screw threads are properly pitched, rendering the clamp virtually immune to vibration-caused back-off.
Click HERE to see the full product line in the Barefoot International catalog
Once you have determined what you would like to order please send a PM to the CrewAdmin with Flyhigh product numbers, quantity needed of each, color, an any other needed information. Afterwards a PM with the total cost and instructions to finalize the order will be sent to you, once the order has been paid for it will ship.
Remember when you receive the pricing information please DO NOT post it anywhere on CenturionCrew.Com or any other site. The pricing information is private and should only be shared between you and the CrewAdmin. If anyone ask you for pricing on a Crew Deal please refer them to the CrewAdmin. We spend a lot of time setting up Crew Deals for the benefit of all the members of the CenturionCrew.Com community and want to keep being able to offer great Crew Deals in the future.
Please post any questions and we will do our best to get a answer the same day.
This Crew Deal close date has not been determined
Regards,
CrewAdmin
Elitist    1
Has this crew deal started yet?
Elitist    1
I think I did already, but no reply .
dezul    10
Admin,
Send me a quote on the largest two rear ballast for an 06 Elite V. I have the Lightning and I am looking to upgrade the ballast.
Thanks.
Admin,
Thanks.
I'm confused by that post... but, I have an 06 Elite V, and the biggest bag that'll fit the rear lockers is the 750lb bag. Now, do what you're supposed to do and "PM" Crew Admin with the model number and I'm sure you'll get a great quote.
dezul    10
haha, sorry. I drunk/ quick posted on here last night. I will be sending a pm soon.
LOL, it's ok, you're not the only one that does that around here I'm sure.
LMAOROTF!!!
...................................................................................."H"ahahahahahahahahahahahahahahahahaha
Faction1    0
Love the fly high sacs! Enzo sac or bust!
PM sent to Crew Admin. Looking forward to hearing back on pricing. Need to get some ballast added before the Summer closes out here in the PNW.
trueblue    3
Is this deal still available? I would like to get a fat brick.
Yep, pm admin :thumbsup:
Guest
This topic is now closed to further replies.
