surfthis
actual physical demensions of the rear ballast tanks
surfthis    0
Just wondering if anyone knows the lenght width and hight of the ballast tanks in the rear of the v drives from 07 and up i know forsure that the weight on the rear tanks are 209lbs each and the center is 225lbs....i want to replace these with larger custom made tanks....i just need to know the size of the stock tank....i would measure them myself but dont have access to my boat for another month....thanks for any help
Packrat    13
I am picking up my new SV230 this week and I could measure it then as I had the dealer remove the port tank for an Enzo Sack.
If you are planning on having a soft sack replacement of similar size you might consider the Fly High Pro X side sack they are 260 lbs (not v drive sack) Of course you could always go larger than that. The next step up is 400 lbs ie V drive sack and then 750 lbs the big one.
They also have a tube sack 370 lbs and some other ones too but I would stick with Fly High Pro X series in my opinion.
