dremmick
Dial in my wave 04 SV230
dremmick    0
Need helping dialing in my surf wave on my 04 Enzo 230. Doesn’t have much push at all. I need to verify speed with GPS next time I am out to ensure my gauges are accurate. Running 1450lb Enzo bag port side and 650lb bag starboard side running partially in rear locker and under observer seat behind driver.  Also running a delta wakeshaper.
Troy. R    199
I haven’t heard much in terms using a wake shaper on an Enzo. My opinion is that you probably don’t need it. That Enzo hull likes to lean.
Start by filling your Enzo sac on the port side, keeping the starboard empty, and running at 10.5 mph. You’ll probably end up needing more weight, but that will give you a good baseline to start from. Adding weight to the rear/under the port side seats will make the wave bigger. You can play with the speed too (I wouldn’t recommend over about 11), but if I recall correctly, 10.5 is what most of us were running with Avys/Enzos back in the day.
...don't counter-sink it from the other side... you might need to get more weight forward (you don't wanna be poppin a wheelie down the lake), but keep it all on one side, until you are pushing +2k pounds.
Good rule of thumb is get one side of the swim platform 12" under the water, and the other end is 12" out.   At this point you'll notice to only turn back to your rider on the "sunk" side.
You shouldn't have to screw around with a "wake shaper" ... that might be icing once you got this cake baked.
...and you're going too fast.
