localdj77    0
Hey crew!
First time poster here as I'm looking at purchasing my first Centurion.  I'm coming from a 1994 MC Maristar.  Its a fantastic boat but rather than trying to make it do something it wasn't designed to do......I'd rather change it up!
I'm going to look at an 2007 Avy C4 this weekend.  Besides typicaly boat stuff......what typical problems do they have and should I look for?
I'm excited to get it, assuming its as advertised, but like to educate myself as much as possible ahead of time.
Thanks in advance!
18 hours ago, localdj77 said:
Hey crew!
Thanks in advance!
Welcome! Congrats on the potential new purchase.
‘07 Avy C4 was my first boat. It’s really a great platform. That hull can create a fantastic surf wave when weighted properly.
Assuming you’ll be taking it on a test drive before buying, just check all of the functions (ballast, blower, perfect pass, trim tab, lights, gauges, stereo, etc.).
Does the boat have aftermarket ballast?
jtryon    24
make sure you cold start it to see that the IAC valve is working properly and you don't need to give it gas at startup.
check when the impeller was done last.  the impeller housing on these gets a groove worn into it if the impeller isn't changed frequently enough, and that causes priming issues which could make it overheat.
the dipstick for the vdrive is impossible to get to, so see if they have any record of vdrive maintenance which is just a drain and refill really.  check the color of the trans fluid as well, it should be a nice dark pink.  easy to do yourself after purchase but it shows if they took care of it.
ask in advance if it has one ballast pump or 3 which might indicate if it's been upgraded.  the stock setup in some cases was one pump and a sprinkler valve which filled both rear bags, which isn't ideal.  it's a relatively easy upgrade to single pumps but equals work, if that matters to you.
hopefully it doesn't have Sideswipe exhaust with dual exhaust outlets out of either side of the hull?  you can tell from pictures.  you want the exhaust exiting from the rear.  again, upgrade-able but that one is a lot more work to do.
check that it has Perfect Pass and it's working.  also check the multi-function gauges as some of the functions tend to go out.
Chris O    15
Yes, all the things that the other guys said.  Plus make sure its actually a C4.  I have see non C4's advertised as C4's.  If there is a need to do ballast upgrades, prop upgrade, convert sideswipe to fresh air exhaust, etc.  These costs can start to add up quickly so make sure they are in your budget.  Plus add in boards, life jackets and other accessories.  Good luck, and if its not the one be patient, dont force it, the right boat will come along.
Chris
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
