Aussiec4elitev
2010 elite v headunit replacement or surround replacement
hi crew,
wondering what's the best way to go about replacing the head unit in my elite v its the one that has an integrated surround however that has broken and being in Australia centurion parts aren't the easiest to find
I've also done a fair amount of googling is that a standard part has anyone else removed one or worked around not having one and somehow still got a headunit in there
at this point I'm thinking i need to go somewhere and get one 3d printed and use that to hold a standard single din unit
photo of factory thing I'm talking about attached
On 10/25/2022 at 11:40 PM, Aussiec4elitev said:
hi crew,
Are you talking about just the head unit plastic cover?
If so, that is not a Centurion part. I think most single DIN head unit marine covers would work. Here's a similar one I found on Amazon:
https://www.amazon.com/MCK2000B-Marine-Cover-Retractable-Black/dp/B019IHQVG2/ref=sr_1_16?keywords=marine+radio+cover&qid=1666876088&qu=eyJxc2MiOiI0LjM4IiwicXNhIjoiMy45MiIsInFzcCI6IjMuNzAifQ%3D%3D&sr=8-16
As for the head unit itself, you can replace it with any single DIN unit.
Hope that helps.
i was looking for the plastic cover
the ones i found by measurement don't seem to fit
i guess what i was asking is does anyone know which one is specifically in there or was there
