h2ohangtime    4
Is it possible/common for a grenaded impeller to warp the housing?  Boat is a 2007 Typhoon with the 5.7 Black Scorpion.  Impeller shredded on the trailer during spring cleaning and setup—no problem, I thought.  Cleaned out the housing (have all 8 splines) and found no debris in the transmission cooler or anywhere else downstream.  Backflushed everything I could.  Installed new impeller and upgraded plastic pump housing cover with the wear plate.  Also R&R’d the thermostat while I was at it.
The issue is that the impeller is not priming/pumping water. With the engine running and water flowing into the pump (installed T and hose fitting in the output of the V-drive), there’s no water reaching the transmission cooler.  This tells me it’s one of two things:
  1. an ill-fitting impeller
  2. the pump housing was warped when the original impeller shredded
Is there anything else I should be checking?  I DO get a lot of water flowing out the thru-hull intake as it goes backwards through the v-drive, but the pump still wasn’t drawing water when in the lake, either.  I have NOT tried to rev the engine to get the pump to prime, but maybe that’s the next test?  I certainly don’t want to overheat again.
I’m at my wits' end trying to figure this out and get us on the water.  Appreciate any other ideas you have.
*** Cross-posted @ Wakeworld ***
jtryon    24
the priming thing happened with mine when i was doing my first impeller change after buying the boat.  the PO didn't use it much in the 5 years he owned it so must have never changed it, and the old one wore a ring where it rides against the pump housing.  i see you already installed the plate that goes between the two halves of the housing to fix the issue when you install a new impeller.
call Steve Buttrick at C&S Marine Pumps.  i got my impeller from him, and when i went to install it he had included a note in the box that stated this exact issue being common for the Merc motors.  super good guy to work with a he was a fraction of the cost of others that i was shopping around.  i bet he can talk through what it would take to get yours fixed.
C & S Marine Pumps Inc
149 s Highway 97
Cantonment , Florida 32533
Edited by jtryon
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
