Txstang125    0
Had this code pop up Sunday at the end of the day. I acknowledge it and it still beeps every minute or so. Can’t get into dealer till next week and have a trip planned this weekend is it critical ? Is there another way to clear it ?
code spn:105 FMI:15
code spn:105 FMI:15
As you probably already searched and found, this fault is Intake Air Temperature higher than expected (>200 deg F). Is the fault persistent after allowing some cool down time?
What boat/year/model/engine are you working with?
I would check the spark arrestor for any type of debris/blockage, clean the spark arrestor while I was at it, then test. If the problem persisted, replace the IAT sensor.
I also found this. See page 46:
http://www.wakeflot.ru/doc/PCM_Diagnostic_manual.pdf
Txstang125    0
It’s 2022 fi23 with the 409 with 27 hours on it  I let it cool down but still beeps every minute
I’m not sure how you would clear a code on one of these boats without dealer intervention? And based on the PCM troubleshooting doc I attached previously, it said this fault will also result in a 50% derate, so I’d definitely want to get it addressed before going back out.
Is there a Nautique dealer near you that can get you in sooner? They’ll also have PCM certified techs.
Edited by Troy. R
