N901    4
Hey All,
Been contemplating FAE all winter. Is it easy to install? Is spray an issue? Mastercraft dealer told me to research back pressure and if it’s a problem with the black scorpion?
thanks for any input in advance.
Chris O    15
I'm glad I put it on mine to replace the sideswipe.  There is a small amount of spray, but not enough that I care about it.  Pretty straight forward install.  Just gotta get over the nerves of putting huge holes in your boat.  There was definitely a part of me that put the project off out of fear of screwing up.
Avy06    5
Chris, did you do the muffle delete with your fae install? I’m waiting to pull the trigger on a fae but need to decided on Y or T?.? Also need to make a decision on delete muffler?
jtryon    24
i'd delete the muffler.  i don't even hear mine running with no muffler, plus now everything in the back of the motor is much more accessible now.  i think the muffler was necessary with sideswipe because it's so loud at cruising speeds, but not with FAE.
N901    4
Is the muffler on these the straight piece that  runs along the back the engine?
Curtis    1
Yes. Big fiberglass tube.
N901    4
Ok got it thanks! Spoke with Larry at FAE today. Im going to remove the switchblade mount as I don’t use it. He needs to me to measure center to center on the bolts so he can make a plate to go in its place.
Curtis    1
I did the same thing. I keep my boat in the marina for 6 months out of the year, and hated carrying the switchblade around all the time. I might be inclined to keep it for special surf days if I was trailering all the time.
Beware that the Switchblade plate may be structurally bonded to the hull in addition to the bolted joint. There's a big risk that you can damage the fiberglass (and not just Gel Goat) trying to remove it if it was bonded with permanent adhesive. I opted to just remove everything from the switchblade setup except for the plate. I just cut back the vertical support mounted to the plate to clear the FAE. Should help reduce the spray I was getting from the Switchblade apparatus when it was unused.
N901    4
Ahh gotchya. How did you cut it back? Literally just hacksaw it?
Chris O    15
Yes, eliminate the muffler.
Curtis    1
Angle grinder with a cutoff wheel. Then smoothed it out and polished it up.
N901    4
Excellent. That might be the trick
