Canyon Mike    0
I have a 2019 FI23 with less than 25 hours. Was on water yesterday and PNP bags won't fill.  Electronic dash shows they are filled.  Any ideas?
Hey @Canyon Mike
Welcome to the crew!
There should be a breaker (50 amp or so) by your batteries. Check that first. I had this exact same thing happen on the ZS232 the first time I took it out and it turned out to be that breaker was tripped. The ZS Doesn't have Ramfill, so it's all pump fed (8 total pumps). There ended up being a recall on my boat to upgrade that breaker to 70A.
Canyon Mike    0
Thanks for your response.  I had already checked the breaker and that was not the issue.  I can't tell if the ballast is filling or not.  My guages seem to be malfunctioning.  I know the PNP's are not filling as I can easily see them.
The PnP are probably time based, so it would make sense that when fill is selected it shows that they are filling.
Can you hear the pumps running when attempting to fill?
DaveB    5
What happens when you try to drain them?. But if the computor thinks they are full, maybe try to trick it by draining an empty bag then fill. I know it sounds stupid but obviously its something simple. I have a FI23 but luckily everything has worked so far.
Canyon Mike    0
Canyon Mike    0
I can hear the pump on one side.  It appears it is in drain mode even though I am hitting fill on the touch screen.  I believe this could be a software issue.
A ‘19 should be under warranty. I’d contact your closest dealer.
    • HennyRi257  »  chowder2016
    • harlobra
