1 hour ago, Dr.NELSON said:
Has anyone had hull leaking issues with their RI237?
There is a lifetime structural warranty. However, shaft seal, Ramfill connections, or something else seems like it’d be a more likely culprit.
Dr.NELSON    0
Thanks Troy
After doing research, asking other owners, they have had problems..leaks with the ramfill connectors on the Ri237 have had leak issues. My boat is a 2018 and it has leaked from the initial delivery and now it has caused corrosion in the motor compartment. After 1 month at one dealer and another 8 months at another, the problem is just starting to get diagnosed. Right now the blame is on me for using the boat in salt water. I have read post that document the Ri237 series leaking around the shaft seal. Will keep you posted on Centurion's response.
  • Sad 1
This sounds like a disastrous headache. I wish you the best @Dr.NELSON
    • HennyRi257  »  chowder2016
    • harlobra
