Pdise    1
Was putting Jabsco ballast king reversible pumps for my lockers anybody ran 2 pumps off one thru hull
and had any problems ? it is 1 inch thru hull
On my old Avy I ran 2 Johnson’s off of one 1” thru-hull. I also ran a ballast puppy and a Johnson off of another on that boat with no issues.
jtryon    24
you'll be better off just adding another 1" thru-hull, but it would work.  you could run two just fine off a bigger thru-hull like a 1.5" though, and re-use the 1" for the center ballast.
The flow capacity of a 1" thru-hull better matches that of a single King. Id install a 2nd 1" thru-hull.
