When I changed the pitch of my prop last year, I noticed a change in the push of the wave for the better. Wave looked the same but i could feel the difference.
Awesome to hear the changes to your boat made that kind of difference.  I love the FS series and with this info it wouldn't hold me back from getting one with which ever engine. But I'll be keeping my Avy for the foreseeable future.
Great job for thinking outside the box!!!
Well I finally had enough people in the boat to do some surfing this weekend. The wave was great, and the surf RPM was 2900-3000 RPMs from 11.3 to 11.6 MPH with minimal current. There is more lift in the rear of the boat now, so I am going to move 100 pounds of lead from the front of the boat to the back and see how that works out. Not sure if I will get to test it before My Lake Powell trip at the end of the month or not.
Awesome!
Since I’ve been getting a few private questions, I will post this to help someone if they decide to attempt on their boat.
The important things:
1) The biggest thing to make sure of is that your front motor mounts have room to adjust the front up and that the rear ones have room to adjust the rear down. You will need more clearance total between front and back than the thickness of the wedge. For mine I adjusted the about an inch total up and down.
2) The next important item is the through hull. Mine was near the bottom of the opening before the wedge and near the center afterwards.
3) The other import items are how much space you have on the prop shaft between the prop and the strut. The prop will be ¼ to ⅜ inch closer after adjusting.
And finally, the dimensions for your wedge. I changed mine 1.5 degrees with my wedge. You have to calculate where the wedge is to determine the wedge thickness for each end of it. If I’d gone any larger I would not have been able to get my engine aligned.
Here is my wedge dimensions, which may be significantly different for other boats.
Edited by volzalum
flashpoint    0
so it has been a year now since i did this exact procedure after reading this on here and I can not be happier. We have a 2016 RI217 with the H6 and had the 15" x 14.25" prop on it but found i could not get up to surf speeds when i had more then 4 people in the boat and 400lbs of wake ballast without dropping the centre plate down and i don't like to use much or any centre plate for my wave. This past season we put 100 hours on it with no problems at all. Now using 700lbs of wake ballast we can even get up to wakeboard speeds if i ever want to do that again sad to see those two boards just hanging around doing nothing. Using the 16" x 13" prop now and our RPM went from 4200 down to around 3800 I do not care about top speed it does 25 mph just fine going to and from the gas dock other then that its fill and surf. I was nice of Volzalum to do all the leg work on figuring this out and it might not work for all models. After changing the motor angle to line everything up it is now closer to the steering cable mount ( will make for changing just that much harder )and driver side fill tube on the ram fill but no rubbing just things to watch for. i did gain on the space of the fuel control cell since there was rubbing going on there when we got the boat. Since they did change the shaft angle on the RI in 2017 i figured something could be done to the 2016 and since i could not find out the part # of the strut they used in 2017 this was the next best thing and probably the cheapest since i am in the metal fab biz.
Happy to hear this is working for you too. I am definitely happy with the change on mine.
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
