mspring135    0
I have an '05 Elite V C4 and I'm in the process of wiring dual batteries with a Battery Doctor Isolator. Hooking up the isolator is straight forward per their diagram. I have a deep cycle battery for the second auxiliary battery and a cranking battery for starting. The question that I have is regarding swapping over auxiliary equipment to the Aux Deep Cycle Battery (#2). I would like to do more than just hook up my amp and stereo to this battery. I found the distribution block with all of the fuses for lights, ballast, stereo, blower, bilge pumps, etc. under the dash (see attached). Can I disconnect the power feed wire for this distribution block (top, red, 10AWG wire that is coming from somewhere in the engine bay) and run a new lead to this distribution block directly from the Aux Battery? My concern is that if I feed this block from the new Aux battery and then run the engine (all of the gauges, sensors, ECU, etc. are now powered) is there going to be something that is now being fed power/connected to both the starting battery and Aux battery? I can't find any wiring diagrams for these boats to see where the power branches off from the main cable (starting battery) (ECU, sensors?) and would also potentially be provided power by that distribution block that is now being fed from the Aux battery (most likely what ever that ignition fuse powers, top right, yellow 20A). Thanks!
mspring135    0
Here is how I am planning on wiring my system. My idea is that the isolator should automatically maintain both batteries charged and the "house" loads from the fused distribution block can be run completely off of the new lead coming from the Aux second battery, which will also be charging while the boat is running with the isolator working. If for some reason the Aux battery dies, I can use the Perko switch to re-align power to the house loads from the factory lead that was lifted and moved to the Perko switch from the starting battery. The isolator can also be overriden to connect both batteries in parallel if the starting battery is dead.
I just want to make sure that I'm not overlooking the way that things are connected back in the engine compartment and inadvertently have some weird circulating current or interconnect the batteries through the engine bay wiring.
Have you contacted your "battery Dr iso" dealer for assistance? Most of your diagram is is incorrect.
mspring135    0
Which part specifically, the battery doctor isolator is wired per their drawing. I also understand that the perko switch is not wired typically to the battery but rather further down the system.
mspring135    0
I also realize that it looks like a child’s drawing lol, please don’t let that distract from the question.. To clarify, the line running from the “engine” to the “2” position on the perko is just the factory lead that goes to the fused distribution block currently.
Not judging the art work in any way, simply the electrical flow and termination points. In your drawing, nothing will work, boat wont start but with the switch on only one position. Everything will be drawing off the AUX battery. That schematic from Battery Dr does not include a dual bank switch, so its not a good representation of what are wanting to accomplish.
mspring135    0
I appreciate the help on this, I may need to re-draw to better show the arrangement. The way that (ideally) I am looking to have things wired would be to either have power being fed to the “house” loads from the aux battery or from the original hot lead which is powered from the starting battery. Also, I want the isolator to recharge both batteries without having to flip a switch, which as I understand it, is what the battery doctor style isolators do. This way I can sit with ballast, stereo, lights, etc. without having to worry about being able to restart should the aux battery die. I see now that I also would want to keep the fused “Ignition” lead under the dash fed from the original hot lead from the engine bay/starting battery to accomplish this. I was trying to avoid wiring a new second distribution block for the house loads since really all but the ignition lead (gauges/starting) would be moved over to a new aux block.
mspring135    0
I was thinking like this, only with the switch only handling the house load power source not two different circuits since the isolator can connect both if needed for an emergency start.
You do not want to have starter draw going through the VSR isolator. Your switch is quite different then the one in ^^^ this illustration. Your switch is designed, and intended, to have all loads go through it, with a couple of exceptions, depending on the boat. Despite the switch difference, as you can see, all loads are going through the switch on the above illustration.
Based on this and the rest of this post, you have the least ideal switch, to do this.
mspring135    0
Let’s take the switch out of the conversation for now since it’s not really necessary with the battery doctor isolator. If I do the following, what issues do you see:
1) Wire the isolator per the diagram from battery doctor. As I understand it, this should maintain both batteries charged and allow connecting them for a short duration to start in an emergency.
2) Run a cable from the auxiliary battery + to the fused distribution block under the dash so that all the house loads (except ignition and gauges, below) run off the new battery.
3) Move the stereo system power to the aux battery.
4) Retain the original distribution block + cable to power the ignition lead which will be moved off of the factory fused distribution block to a new fused line. This will retain the ignition circuit/gauges on the starting battery and shouldn’t cross power paths with the aux battery hotel circuits as far as I can tell looking at the Merc 350 Mag MPI schematics.
Thanks!
In simple terms, the voltage sensing relay isolator, allows charge voltage to pass from the main bank to the house bank, when there is charge. And, prevent loads from each bank to draw from the other bank, when there is no charge. So the introduction of the device, changes little to nothing, regarding the wiring of the rest of the system as it pertains to the style of switch you have.
If you leave out the main battery switch, you lose 2 important functions. 1) the ability to separate the loads from the batteries, when the boat is not in use. 2) you do not have means to use the house bank for emergency starting. IMO, the switch, and the proper one for the design, is the backbone of the battery system.
I know the battery dr unit states it has a manual combine mode for emergency parallel starting. As I stated, I would not do this. That unit has a 150A peak. A V8 starter can easily peak north of 250A, then level off around 200A once the engine is up to starter speed.
mspring135    0
Good point on the isolator max amperage, I missed the fact that the 150A fuse to the aux battery will blow if you try to cross connect to start using the battery doctor. If I add a 6011 switch or equivalent, that should enable me to keep the circuits separate as well as interconnect for a dead starter battery and bypass the VSR, correct? I definitely overthought this one and came up with a dumb plan, thanks for the help.
I'm still a little hesitant on the ignition wiring, specifically, having the ignition circuit on the starting battery and everything else powered from the fused distribution block from the other battery would result in the two batteries being connected, i.e., voltage differential, somewhere down the line in a relay, sensor, etc. I would not think that this would be the case but want to make sure before something gets fried.
To test this out so far, I lifted the + 10 AWG lead to the distribution block as well as the ignition lead from that same block. I used a fused test lead to power just the ignition lead and verified that all necessary things to run the boat (gauges/ecu/starting circuit) have power which lead me to believe that I would be okay splitting out the power sources.
A Blue Sea Dual Circuit Plus switch and VSR will allow you to achieve:
Zero non-critical loads connected direct to a battery
isolation of the main and house bank while under load
Charging of both banks while engine running
One step ON and OFF
Emergency starting.
Dedicated house and dedicated main cranking banks
If that 10ga B+ supply to the helm fuse box does not connect to the existing battery's B+, then it likely terminates to starter main post or somewhere else around then engine. You would have to either relocate this, or just run a new supply from the house side of the switch. If the key switch's B+ input comes from that fuse box, you also need to pull that off and draw from the main side of the switch.
I'm running the battery dr. for about 3 years now and it works great for me. It makes sure the start battery is always fully charged and then starts charging the house. I monitor the batteries and if they start acting weird then I replace. While the boat is at the house I also have an onboard charger that I plug in.
My boat had several wires connected to the single battery from factory. I found the wires that go to the starter and alternator and put them on the start battery all the other wires went to the house battery. everything works like a champ. one thing I did that the battery dr. didn't have was I put a switch inline so when the boat is at the house, and I plug in the onboard charger I can turn off the battery dr.  I put the switch in line for the ground wire (4) off the battery dr.  When I get in the boat, i flip the switch on and the battery dr. does the rest.
I think I did a write up on my install. I'll see if I can find it.
Edit: didn't find where I did a write up but Wylie-Tunes and I discussed it on this thread also.
Edited by Troy
After researching Wylie's suggestion, it is a much better route but at an added cost and install headache.  if you have the time, talent and money go the Blue Sea route. This kit looks like it has what you would need. https://www.bluesea.com/products/7650/Add-A-Battery_Kit_-_120A
Would that be a good kit Wylie_Tunes?
