Jbeams2
Winterization Checklist for 2004 Centurion Enzo SV230
Jbeams2    0
Prior to this boat, I had a direct drive. I winterized each year on my own.
Could anyone share their winterization checklists for a V-Drive? Also any information for draining/winterizing ballast.
I have been reading some posts about draining the heater as well, but I wasn't sure if my 2004 model had that.
Any information would great!
Someone just posted a detailed write up on the FaceBook group. Winterize the engine just like you would on the Direct drive. IF you have a heater blow the water out of it, add some anti-freeze. Add some anti-freeze to the ballast bags and then hit empty on the pump for a bit to put anti-freeze in the pump. Hard tank? use the "in" pump to pull anti-freeze into the tank.
That is all if you live somewhere it gets real cold for a long time.
For me in TX and my boat stays in my insulated shop. I pull the plugs to the engine to let water out of it. Remove the ballast strainer and empty the water out of it. and Change oils. I don't have a in boat heater and I don't worry about my ballast pumps, bags or tanks. It doesn't get real cold and when I'm out in the shop I turn on a heater, so rarely does the shop ever get cold.
Jbeams2    0
I have an 04. How do I tell if it has a heater?
Do you heater hoses up by the driver and observers seat? Usually the boats that had a heater installed had pull out hoses or outlets up by the driver and observer. 131613802.jpg.3f3c0b3747b268fa9a5daa9a30297483.jpg
See the black circles under the observer seat and by the walkthru? Heater outlets. Just a quick example.
Edited by Troy
Added picture
