Ryan Materi    0
Out for 3-4 hours straight.  Absolutely no problems.  Came back in, as pulling on boat lift.  Boat shut off.  Won’t start now, just cranks.
Tried starting 8-10 times
Boat is right up on oil level, so not that..
Apon reading up in manual, have realized that fuel filters should have been changed by now, as boat has 140hours on it.  And still original filters.  But the boat seemed like it shut off before I even took it out of gear.  Not sure if it could be something electrical? Or am I over thinking this and just try filters first.
Thanks in advance
Ryan.
Are you positive you are good on fuel?  The gauge on mine fluctuates wildly. If it is cranking, I am much less likely to believe it is an electrical issue.  Is the lanyard still fully in place?  I know on my old Yamaha the boat would crank, but not fire if the lanyard was removed.  I fell for that one more than a couple of times.
