Anson    0
2006 Avalanche w/6.2 Black Scorpion. For whatever reason after running and then shutting down for more than 30mins, it will not start. It seems like a vapor lock.  Runs good with no hesitation at all when running.  I installed a new booster pump, water separated filter and fuel filter, but it still does it.  I  managed to get it started by using full throttle a few time. I’ve also had to be towed in a few times and have start without any problem in a few hours.  After looking online, it seems to be a common problem, but I haven’t found a fix.  If anyone has any idea, please help. Also, where is the fuel cooler installed on this thing and is it even possible to get to it without removing the entire engine.
Sounds like you are on the right track with the vapor lock.
Maybe try keeping the engine compartment open.....as well as run with the blower on to keep removing the heat from the engine bay. If nothing else this will verify for sure that vapor lock is your issue.
Have head that you can install a fuel cooler check valve that may help.
Found this too:
Pour cold water over the fuel pump and fuel lines while the ignition is in the off position. This will quickly cool down the fuel pump and condense the fuel from vapor back to liquid form, eliminating the vapor lock in the fuel pump and lines.
  • If you are routinely having problems with vapor lock in your vehicle, wrap the fuel lines leading to and from the fuel pump with aluminum foil. This will help insulate the lines and prevent the fuel from heating up to the point of vaporization.
Here is a link to a pretty detailed write up on vapor lock:
https://www.perfprotech.com/blog/articles/mercruiser-vapor-lock
rhino89523    34
Don't have much to add, but I love old Internationals and they are the king of vapor locking. Insulating the fuel lines in the engine compartment fixes it on IH's. the make some pretty cool sleeves and they make some stuff kind of like aluminum foil with some good sticky stuff to hold it together all sold at Summit Racing.
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
