alexan10    0
Getting a maintenance warning alarm that comes on every few minutes.  My OBD reader that I have will not work on marine engines.  Anyone know what reader will read codes from the engines on Centurion boats?
Dillyrev    0
I had mine come on a few times this past weekend, after starting boat. Everything looked fine so I ran it.
Jlagos    23
Ditto for me on 2010 enzo 240. All fluids and gauges are within normal limits. Found a thread that mentioned the knock sensor was a culprit however changing them did no good. Unfortunately the local centurion dealer has a back log of 5 weeks before thay can hookup the computer for a reading. Dang that warning beep sure is loud. I'll probably check into the local nautique dealer to see what's the wait there. In addition I'll change the fuel filters considering I skipped that this year. I'll let you know if it resolves the problem but I doubt it. Mine started beeping shortly after I noticed oil leaking past the oil filter gasket.
