rrd525    40
The throttle has a small creep right in the cruise range. If we want to hold at 3800 RPM, it will slowly fall to 4000 RPM. I looked into the Teleflex CH2200ENC throttle manual and it mentions a throttle brake, but I can't find the adjustment screw. Do you remove the chrome bezel and handle? I can't match the location they reference in the diagram on page 2, top right corner.
http://www.marineengine.com/products/technical_information/CH200ENC_side_mount.pdf
Lofty    0
Experiencing the same, ill let you know if I find anything.
Subscribed!!
Mine has always had it as well.  Seems extremely loose in the mid range and wanted to be able to tighten it up so it doesn't move on it's own but could never figure out how to get behind the handle to adjust!!
