jfillbrandt    0
Hey Crew!
I have a 2007 Enzo SV216 and my STBD Ballast tank wont empty. Originally it would not fill either, but I found that I had a bad fuse and swapped it with the one for my Port side which was working fine. After swapping the fuse I can now fill the STBD side, but it won't empty. Any thoughts on this? I haven't dug into it yet aside from swapping the fuse just because I didn't want to start ripping into things without a little more knowledge. I'm also unsure if this boat uses separate pumps for Fill and Empty, as I know other boat makes/models do. I've been having a difficult time finding information on some of these basic items...manuals, tech notes, even searching through content on this forum. Trust me, I've used the search function a lot!
Again, any help or insight here is greatly appreciated!
swetpants    0
I don't have an enzo so I'm shooting from the hip here, but on our Elite, the factory used a ballast puppy to fill and a cartridge pump to empty. They have separate fuses, so check all your fuses for any that might be blown. The cartridge pump will probably be attached to the factory hard tank, where as the ballast puppy is usually located in the v drive compartment. Lift your back seat up to see if you can find it.  The impellers on the ballast puppy pumps should be changed out every year or so depending on how much you use it. $35 and an easy fix. Otherwise old ones get stuck and pop fuses (probably why it popped in the first place). Cartridge pumps go bad also. Another easy fix. Change out the cartridge and will run like new.
Packrat    13
I just replaced mine on sv230 Enzo. If you can get to the rear of the tank after lifting the tab on the cartridge unscrew just the cartridge and lift it up and out. Snip the two wires on the bad cartridge as close to the old cartridge as you to leave as much wire as you can to connect to the new cartridge.  Buy this replacement cartridge being sure it’s the 3/4” 1000gal model (not 500gal)  look at the new cartridge and you can see the two wires.
https://www.amazon.com/Mayfair-Replacement-Cartridge-Pump-28512/dp/B00DHRGBC4/ref=sr_1_5?crid=1FRQVCWFEBWRB&keywords=mayfair+replacement+cartridge+bilge+pump+motors&qid=1562296637&s=gateway&sprefix=Mayfair+repl%2Caps%2C277&sr=8-5
just strip the wire ends and attach to the two wires left after you took out old cartridge.
Edited by Packrat
Edit
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
