ItsMyFirstTime
Boat Lift Setup
I'm trying to configure my Shorestation lift for my new S211. It's a 5000lb capacity lift so it should be fine on weight, but with the bunks fully extended above the cradle, the boat hangs off the back of the bunks almost 2' to the end of the hull. I cant go much further without the prop shaft contacting the cradle.
Do you think this is okay for the time being until I can figure out if I can get longer or higher bunks?
Edited by ItsMyFirstTime
