byerman    5
2014 233 Enzo worked great before winter. Winterized and left in a garage. First trip today--no CATs fin movement, no wake plate movement, no valve movement. Valves show they are working on the screen but the CATs and the wake plate don't show any response on the screen. Radio intermittently working. Front ballast pump not working. The screen looks fine and responds to touch otherwise.  Any ideas? Any help is appreciated. Thanks.
You probably need a computer update.... Dealer can get the software and update using USB thumb drive.
byerman    5
Thanks InfinitySurf. I am hoping that is it.
Just as a side note, did you check and test your batteries to be sure they are all good? (I check water level in Spring/Fall and top off using distilled water), a charger/maintainer will keep them in good shape. Many computer issues are caused by low/bad battery so wanted to mention that in case they are original batteries in your boat.
Another possibility (tho seems more remote based on what you posted)....if you removed batteries for the layup could be the computer reset itself somehow when they were re-installed and in the dealer settings turned off the CATS and Ramfill settings since they were options in 2014. Just speculating tho it seems most likely that it just needs an update/re-flash.
In meantime tho after testing batteries to be sure they are still good, I would disconnect the batteries for 20-30mins and then re-connect and see if that fixes anything. That may reset your system. I think in dealer settings there may be a "factory reset" as well but don't remember for sure). Code is 91 to access dealer settings.
On Valves, you know you can manually open/close them right? Maybe they need to be manually cycled to free them up....have someone cycle valves in trailer mode while you are looking at them to see what they do. When my boat is out of water, I use the trailer mode to open the valves and leave them open till ready to dunk boat again. It keeps them from getting stuck and less historic failures for others from what I have read. I still have the original Drainmaster valves on my 2014 SV244 boat with no failures but I lube them every few outings with a water resistant silicone (then I cycle them open/closed a few times on trailer to spread the lube) and I also use the trailer mode to open the fill/drain valves every time I pull the boat and leave them open while in garage. When on water, I also fill Ramfill with GPS set on 12-13mph so not as much water pressure against the gates when they open/close since my thot process is that they will last longer that way rather than having water pressure pushing against valves while they open/close going 18mph (I have new Valterra valves for when I need to replace them since its a matter of time.... just have not had a reason to replace them yet tho I will at some point since very happy with this boat and intend to keep it another 4-5yrs).
byerman    5
Thank you. I did disconnect the batteries to check them. After charging, one is 100% when tested and one maxes at 89%. As you thought, they were disconnected. My local dealer will check with Centurion for an update. Meanwhile I will try what you suggest. I appreciate your response and help. I will let you know. Glad to hear your boat has been so solid. I did spray my valves with a Teflon lube and then manually pulled them up and down. They were a bit stiff until the lube spread around. Currently, nothing cycles automatically. I like your suggestions.
Just hope you don’t need to replace that provision II screen. $$$$$$
byerman    5
After reading the suggestions here, I removed the batteries and called Fred's Marine in Layton. Centurion is relatively new to them but they are the dealer. Fred called Centurion and asked them about the problem. He explained to me that the screen has a different electrical supply than the screen. It made sense that the screen seemed to work but none of the accessories worked. He suggested that it could be a simple tripped breaker. It was not a tripped breaker but it seemed to be an electrical problem.
I followed the wires from the batteries to the computer. I took the wires off of the breakers and all looked fine. When I put everything back together, the computer all of the accessories worked. I haven't taken it out yet but with the computer running the valves normally entering "trailer mode," I think that it will work on the lake. Thanks for all of the comments.
Byerman,
I just went through this on my 2014 SV233. In the beginning My screen acted the same way yours is doing. I would turn off batteries, then trip all breakers. Look under the helm and inside the observer's seat. There are also 2 plugs in the back of the touchscreen, I would unhook those as well.  After letting set for a minute I would plug back in and it would work. I was assuming that I might have left the key and touchscreen on while towing at 75mph and this created the problem because my GPS and ZeroOff would not work but never had this confirmed.
So the end result was a touchscreen replacement that I replaced in the winter of 2018-2019. I was able to have this issue covered under warranty so I'm not sure of the cost but rumor has it 1500-3500 dollars which is ridiculous if you take into consideration on what a new Mac desktop costs.
Better bring this screen issue to the dealer because this is a known failure and if they are new they might not know and depending on when you purchased your boat you might be at the end of your warranty.
  • Thanks 1
HutchCanada    4
2015 FS33.  I'm on my second screen.  Still having intermittent issues with ballast going off/on on its own.  Possible that I got TWO bad screens? Or something else? Brand new batteries, both 100%. I still have warranty
How do you guys still have a warranty on these screens?  I was told the screens were 1 year warranty?
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
