TexP51
Replacement Faria Tach / Speedo
TexP51    6
Thought I’d give a product review for some of the ‘seasoned’ Centurion boats.  I have a 2002 Elite V C4 Air Warrior that was recently purchased over in FLA.  On the drive from FLA to TX to get her home the Tach bezel cracked. If you’ve been on I-10 you’ll understand!  The boat had the factory Faria gauges.  Playing around in the dash I found the instrument harness had seen several radio upgrades and was pulled up tight in places with zip ties.  As I moved my hand inside in the IP the tach bezel on the outside broke completely off.  Old plastic and too much force.  The Gaige’s are mounted through the front of the Instument panel and use a squash ring on each gauge to hold in place, so all the force is on the outer ring.  Well mine broke and the tach gauge fell into its hole into the IP.  All of my Elite’ power went through through the tach connection.  Faria has a lifetime warranty for the original owner of A Centurion boat, but they didn’t respond to my email inquiries.  I Just ordered a replacement Faria white gauge,  giving up on finding a Centurion logo with the chrome bezel, and since the speedos were acting up, went ahead and ordered matching GPS speedos that do not used the paddle wheel, and now have internal GPS antenna.  Depth gauge was dead so I replaced it as well.  On Amazon the tach was $120 w/ Hobbs meter, and each speedo was $79, the Faria depth sounder was $140 for a in-hull system.  The euro white worked out well for my taste, but the Chesapeake has chrome trim. If you prefer that.,  Don’t be in a hurry as it does take time figuring out the leads. Generally you could just hook a replacement exactly as the old one, but I had to remove the wiring blindly in the Elite IP configuration, and figure out wiring afterwards.  Also got rid of a few harnesses that were in the IP, as in 2002 you got all harnesses for the various options whether they were installed or not.  Anyway, the GPS Faria speedos (F33147) are especially interesting as an option for us replacing older dash/IP setups.   The speedos have internal gps antenna and just need ground, and a hot wire coming from the ign switch, and 3rd hot for illumination.  Hope this helps somebody else.
Edited by TexP51
Add link
Reefboy    0
I have a 2000 with similar dash.  If I want to inspect the wiring on a few of the instruments, how do I pull the gage out?  From the front side alone? I looked up from underneath and can not see a thing. I'm concerned that feeling up there alone will dislodge connectors. The entire dash is one big piece that wraps around to the throttle control.  I can't believe I would need to remove the entire dash.
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
