So one of the options that was not on my FI25 was swim deck underwater lights. Well we went ahead and picked up some lights from shadow-caster, and was curious if A. the boat is pre wired for underwater lights, and B. how do i apply the icon for underwater lights to the dash touchscreen?
Thank you kindly
What shadowcaster lights did you go with? I ordered our fi25 without and am going with the shadowcaster scr-16 in bimin blue
I went with the scr-24's in white/bimini blue.
Also the boat is pre wired, and you can go through settings to change the options for lights on the dash.
Yes I know we had a fi23 and did lifeforms on it. You need the dealer code to activate once you wire them in
Any insight on why the lights would not be receiving any power when connected to the factory swim deck wiring?
You have to enter the dealer code on top left of settings screen to turn on power to the factory lead
I entered the dealer code to apply the swim deck button to the touch screen. Is there another step I am missing or a lack of fuses for the wiring?
1 minute ago, h20king said:
No that should have taken care of it.
Hmm. Maybe I am missing something then.
15 minutes ago, Nick213 said:
Are your batteries fully charged?
Yes they are. Even tried this while the motor was running, and still had the same results.
Ok, lets start with what you found, that got the lights to come on?
Next, whats a few seconds? This lights have thermal control, and can shut down when they get warm.
Is it possible the lights need a relay installed? The shadow casters draw at least 5 Amps each. On our fi23 we did lifefourm 9 lights and they only draw 2.7 amps each and worked with no problems.
The only way they would stay on for longer than literally one second was to toggle the lights to the blue/white fade option. The longest they would stay on was maybe three seconds.
The next idea I was thinking was to add a relay from the stock power lead with a 20amp fuse.
Ok, thats not long enough to get them warm. But what made the difference between not coming on to coming on, but only a second?
The load of both could be overloading the PDM. A relay triggered by the PDM would be the solution, but you want to make sure the fuse does not exceed the capacity of the wiring to the lights.
The only thing that made a difference initially was removing the underwater light option, and re-applying it to the touch screen. Had me scratching my head.
The amp draw is 7.8 amps per light per shadow casters series diagram. I plan to run a thicker gauge wire after the relay. Alongside a 20 amp fuse that should be sufficient yes?
two pair 14ga to each light or a single pair 12ga for both lights would be how id do it.
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
