h2ohangtime
Opinions on 2007 Typhoon C4
h2ohangtime    4
Hi there Crew,
I’m about to pull the trigger (fingers crossed) on an original owner, nicely maintained 2007 Typhoon C4.  We will be using it about 50 surf/25 wakeboard/25 tube until the kids get bigger and the tubing goes away.
I know the Typhoon has the stepped hull, but everything I’ve read here and on WW states that the surf wave is about the same as an Avalanche.  Does anyone know what the design goal was behind the steps?
Please let me know if you have any thoughts on this boat.  Is there any reason I wouldn’t be able to get a good wave out of this, assuming we start off with 750’s in the rear and a wake shaper/suck gate? Thanks!
I thought they stopped the stepped hull in 2005-2006??? If I remember correctly the guys that had the stepped hulls could not get as good as a wave as the Avy’s.
Pictures?
h2ohangtime    4
Troy, the steps and the cutouts are two different things that seem to confuse people.  This version of the Typhoon doesn’t have the big cutouts at the transom like the older ones, but its hull has steps that run port to starboard around the halfway point of the length.  My understanding is that a lot of bigger boats had that design to increase efficiency and minimize drag—I just don’t understand why the Typhoon was the only one of the Centurion line to incorporate them.
Here are pics of the transom and the hull steps.
9B28F363-3765-412F-AA04-3D4F80F727BC.jpe
B8CC8B81-4219-462E-B2FB-92B2364D18B8.jpe
That thing should have no issues in throwing an awesome wave, but I haven't not seen or rode one to back up that statement.
Yes I was thinking about the big cutouts at the transom. Never noticed the steps but I agree with you on seeing them on larger boats. I remember back in the day of people sharing pictures of their Typhoon wave. Might do a little searching and see if I can find them.
It appears to have the Tribal tower, you will love the ease and head room of that tower.
It also still has the old aluminum swim plateform brackets. over time they will break. Upgrade to the Stainless steel ones before they break. I did and now I don't have to worry and the plateform doesn't "rattle" any more. Much better.
I couldn't find any pictures but I did find several people talk about the 07+ typhoon surfing great. Are you goofy or regular? If you surf goofy, you need an a-plate to really make the wave spot on, unless you have the super rare right hand prop rotation.
h2ohangtime    4
Thanks Troy--I'm regular, but may have the occasional goofy rider.  I was thinking about upgrading the wake plate to the Bennett eventually, but not right out of the gate. I would assume I could couple the A-plate with the Bennett actuators?
I was specifically looking for the Tribal Tower because of how low it folds and the associated head room that you talk about.
Thanks also for the note on the platform brackets--I'll keep apprised of that.
Yes, You can do the a-plate with the Bennett. Search for my thread about the asymmetrical plate addition. It didn't hurt my regular wave but made my goofy wave awesome.  I will say I always leave my plate up all the time. Might go down for when the kids tube a bit but otherwise its always up.  Also when you upgrade ballast, go straight to custom sacs and additional impeller pumps.  You can make the other stuff work but it will cost more in the long run, because you will want custom sacs and reversible pumps. LOL  I also did a write up about my custom sac and pump install.
Edited by Troy
h2ohangtime    4
Right on, thanks again.  Since this one is an original-owner boat and it's been maintained at the same place since they bought it, I'm more hopeful that this won't fall through like the last Avy I was looking at.  Inspection this week and then we'll go from there.
Dan gib    8
As the owner of a 07 typhoon storm series c4 do it. I love the boat and one of the best waves out there. I run 2-1100s in rear and stock center 250# tank and homemade shaper, wave is massive even with two people on the boat. I have it all plumbed in with tsunami pumps. Boat runs very well plows threw chop. Even if I half or 3/4 fill my rear sacks it surfs great.
msg me if you have any questions
h2ohangtime    4
Thanks Dan!  Do you have any problems getting the wake shaper to hold?  It looks like the lip on the side goes a lot closer to the transom than on the Avy--I was thinking of going with the same setup you have if my 750's don't get the wave big enough.  Do you list it at all or is the weight balanced 50/50 in the rear?
rhino89523    34
I don't have the typhoon, I have an Avy. I run a homemade wake shaper and find it to not be sensitive at all to placement as long as it is somewhere below or in the waterline it works fine.  I doubt you will have any trouble getting a shaper to stick.
Edited by rhino89523
Dan gib    8
No I run it even I think listing is a bad option but that just me I know some people like it usually they are folks without a shaper. If you have the 750s you will be good but if purchasing them I would go 1100s.
As far as the shaper it never has fallen off and zero issues mounting it.
Dan gib    8
Post some pics of the boat if you can. Mine is a lot different with the options like fresh air exhaust the evo tower and fiberglass swim deck.
h2ohangtime    4
Here you go--this one should show it pretty well: StarboardAft.jpg
Dan gib    8
Looking good, not a huge yellow fan but seems very clean did you get her yet?
h2ohangtime    4
Yup, picked her up Sunday.  Trailer brakes needed some work, so it's in the shop for that, but we'll be at the lake this weekend.
brkoch    1
Just posted a new topic, but maybe I should have posted here instead.  I am also looking at a 2007 Typhoon that is very low hours.  It is pretty much stock with the smaller ballast in the back and center.  I am wondering if I will have to upgrade these to surf or if they will work as is?  What about the stock pumps?  Also, what wakeshaper's does everyone have?  Will ballast and a wakeshaper be sufficient or is there something else needed?  What should I expect to pay for something with less than 100 hours on it?
Thanks!
codo511    2
Thanks!
Brkock did you end up getting that 07 typhoon w  ~100 hrs? Ballpark price? I’m looking at one right now with 300 and it’s super clean… just trying to gauge values in 2022…
