Dieselbreath
2017 S238 Accessory Switch output
Where do these wires dead end?  It appears the wires leave the output side of the switch, but I am not sure where to find the other end of them.
Thanks all!
So I am stunned that nobody can tell me where these wires end, in order to power up an accessory item.  Some one has to have done some add on accessories.
Wylie_Tunes    139
Dont bother with the end. Disconnect the wire from the switch output and plug up your own wire/terminal.
    • MajaKazazic
    • MatthewsDave
    • harlobra
    • Nick213
      · 3 replies
    • luluzer
    • Guest
      Guest  »  dittrimd
