Arippy427    0
Relatively new boat owner here. Purchased first boat in May - a 2007 centurion elite v c4. Now seem to be having issues with the center ballast. I could tell it wasn’t filling so I popped off the floor cover to take a look at it and the pump. When I hit the empty switch the pump will run, but when I hit the fill switch just get one clicking sound that sound like it’s coming from farther back near the engine (I did have the engine running when I hit the fill switch). I pulled the pump out to see the impeller and it was the same when I tried there as well. Impeller spins on empty, dead on fill, just that same short click noise coming from somewhere by the engine. Is there a trick to filling the center ballast, or is there a breaker or fuse or something that could have blown that’s preventing it from filling? Any help is appreciated. CE839006-8445-4ECB-BD4E-D93C80C9B1A5.jpeg.77e0a91589c554665db37903cca4a104.jpeg66EE19DF-F711-43D5-A5AD-3F5941C7CF88.jpeg.4162f2840a92628b2e255573d26d5e55.jpeg
I would think if you have a blown fuse, it would not empty or make any noise (same pump is filling and emptying?). I don't know that pump well, but I would try taking it apart to see if you can see anything obvious, my guess is that its probably just getting old and may be time to replace. If you do replace you may wanna consider something like Ballast Puppy, they are popular....I have 3 in my boat and they have treated me well. You can get even more GPH by going to Ballast King, but you may have to also change the wiring setup.
Arippy427    0
Thanks infinitysurf. I assume it is the same pump filling and draining as that’s the only area I see anything going into the ballast. I’ve got two more pumps in the back for the rear ballast bags, and I guess it could fill from those somehow and somewhere that I can’t see, but I’m not sure how that would work. The weird thing is this center ballast pump is tiny and has a different set up than the other two pump on the rear. The top of this pump just spins off the pump base and has a small plastic impeller.
I just googled it and found the ad for it says “bilge” pump. Is it possible this pump is only to empty the bilge and center ballast, and maybe one of the other rear pumps or a pump I can’t see is filling the center ballast?
https://www.wholesalemarine.com/mayfair-replacement-cartridge-bilge-pump-motors-35102.html?gclid=EAIaIQobChMIpufAqMuJ3AIVFrbICh2JtQu9EAQYAiABEgLX6vD_BwE
Arippy427    0
What the pump actually looks looks like, though mine doesn’t feel like it’s sitting on a stand like that
That is the empty pump. there is a separate fill pump mounted to the ski pylon structure in the engine compartment.  then it goes from that pump to some sprinkler valves (if you have more than one factory tank) then to the tank. Sounds like the impeller is stuck on the fill pump.
Arippy427    0
Thanks! I think I finally have the system figured out. I have two pumps back by the pylon structure, and I thought each one of those were filling and emptying the two after market rear ballast bags. But, it appears one of those pumps is for the center ballast and the other is to fill both of the rear bags. The one that controls the center ballast I took out and cleaned and greased the impeller andd put it back on and now it looks like it’s filling and emptying the center ballast. I think I probably need to do the same thing with the other pump that fills the rear ballasts as well as it’s been sitting for awhile and sound like it’s working pretty hard when I try to fill the bags. On that same note, another question - is it normal when filling the rear bags for water to be pushed out the side empty port? Thought maybe that was the pump and water pushing air out of the bags but not sure if there was something else that could be going on?
bomoseen avy    45
In my '03 Avy I had all aerator pumps like that. They don't serve dual purpose. Like Troy says one for empty and on my center tank it was mounted right on the back of the tank. The fill pump was on inside back of transom. Do you have mushrooms on the outside of the transom under the swim platform? That is your pump water intake.
From the fill pump mounted to the inside of transom there was tubing that ran to the center ballast tank. This looped up on a bar by the front of the engine before it connected to the center ballast tank. Sometimes it failed to prime and i had to push the tubing down toward the bottom of the hull to allow the water to prime the system enough to start filling. Not sure if this is your issue. The fill pumps are really difficult to get to behind the engine if you have that as your system and not the sprinkler valves
Arippy427    0
Thanks bomoseen! This is what I have going to the center ballast. This is right behind the engine at the transom. Is the piece with the grey top the fill pump?
bomoseen avy    45
Whoa! That is not what I had on my Avy but may be what Troy was talking about with the sprinkler valves. Mine was simple just aerator pumps (like the mayfair cartrige in your prior pictures) attached to the inside of the transom with dedicated tubing going right to the tank. Follow the tubing each way to see if it goes to bag or another pump on bottom of hull. I don't know what that white thing is?!? Sorry for adding to the confusion
That looks like what mine looked like from the factory. The white thing is a filter and the grey thing is the sprinkler valve.  My fill pump is mounted to my ski pylon structure on the port side. I'll try and remember to take a picture tonight. PM me if you want to talk about the system.
Dillyrev    0
Just picked up my wakeboard boat 2003 centurion typhoon, first trip center ballast filled no problem, second trip out nothing. Neighbor brought 3-4 bags to try with a wave shaper, worked pretty good but seemed time consuming getting everything filled and emptied when done. Anyone do the wavemaker system ? thinking about trying it.
I have seen multiple threads where people upgraded their ballast system to bigger bags with reversible pumps like the ballast puppy. It may require drilling some holes under boat for the new ballast pumps as well as holes for the vent lines, depending on the setup you currently have but would make things much easier/faster for you. Money well spent if it gives more time surfing
@Wylie_Tunes can also set you up with a full ballast system and is very knowledgeable about these boats and what you would need.
codo511    2
So I just started following this tread as my 07 c4 typhoon recently has been having center ballast discharge issues and popping  the 5a fuse.
after reading all the threads I did some exploration and I too have a single sprinkler in with individual export bilge for each tank… my issue after lifting the port storage compartment is there is no access, and after lifting the floor out there is only an inch to get at the center ballast pump… turns out they covered over the “port hole cut out access” to that area with carpet and with the stereo equipment / the walkthrough walls to the bow…
any advice?
I feel like that is my only access to my issue… which will then likely be-
- pull all the stereo equipment, install an access panel, replace pump…
Thx
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
