Mitch925    0
Hi, I am having a tough time with my boat I am getting a misfire along the whole RPM range. The motor surges at higher speeds. I am new to the boat scene. I have an 09 Centurion Avalanche with a black Scorpion 350, serial number 1A091118. I have changed every part of the ignition system except for the actually distributor shaft . I changed my fuel pump and fuel filter. I am getting weird alarms. I am getting a misfire alarm and an engine over heat alarm and a guardian alarm when I am out on the water but I still have power. The block isn’t getting hot (159 degrees) and the compression is 150psi across the engine. The motor/boat only has 72 hours on it. I am just looking for ways to help me identify the problem. I am 3000 bucks into trying to find this problem. Anything will help. Any ideas would help too. Some other info is I am getting 14.1 volts out of the alternator all the time.
Thanks,
Mitch
Edited by Mitch925
rhino89523    34
I seem to remember some guys actually having problems with plastic distributor bases on some motors a few years back where the heat had warped the base of the distributor so the cap wasn't fitting right, I think by pushing down on the cap it went away so he replaced the distributor and it was fixed. I'd look at it first of course before throwing more money at it. If everything else checks out I'm leaning toward an ECM malfunction since you have other random electrical stuff going on but don't take my word for that....ECM's are like a G
Hein    63
coolant temperature sensor?
Hein    63
Believe this is the part: https://www.amazon.com/Engine-Temperature-Sensor-coolant-Mercruiser/dp/B00BFJL8JM/
Your temp seems a little low which could throw off timing and air/fuel ratio.  Our '08 runs at about 175F according to the gauge.  I would consider that a bit on the cool side also.  When our boat starts running rough it's time to clean or replace the cap/rotor. Presuming there are no new issues.
fropappy    9
I replace the distributor cap and rotor every 12-18 months.
If I don't, it starts running like crap!
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
