mattmx181    1
Hey guys recently wrote a post asking ideas for California Winterization tips for an S238 and got incredible feedback which I thank everyone of you! Found a good solution for a cover and dehumidifier bags to keep it nice and dry/protected. Also temperatures may creep down just under 32 degrees for no more than a few hours maybe a couple times, so i'm taking the advice on just putting a heater inside the engine compartment to just keep the mind at peace without the hassle of full winterization when it may not be needed. Also will fill the tanks and add fuel Stabilizer. Does anyone have any good recommendations through personal experience or experience of others who use this technique and what good heaters are recommended out there? If anyone has a strong feelings as to this not being a good technique for this winter I am always open for suggestions. Thank You!
lakerat    70
I need to fully winterize where I live but I still keep a Caframo heater ( Cwazy1's first link) in my engine compartment over the winter.  I've only had it one season, but so far so good.
At upwards of 500 watts needed for these heaters I realize nobody is concerned about their electric bill but is anyone concerned about fire?
Cwazy1    89
Well it depends on what you're trying to do. Most people just keep a 300 watt in their engine compartment and drain their heater core to avoid having to have 2.
Also these heaters only kick on when temp dips below ~40 and turn back off when its around ~50.  Its not always on. They're thermostat controlled. It doesn't really consume a ton of energy.
Oh nice that temp control feature would make it more practical then
Cwazy1    89
Yeah for sure. If it weren't temp controlled, you'd be better off putting a 100watt lightbulb safety light and running it on a nightly timer.
Mrwick    65
You might sleep better at night with draining/blowing out everything and not having to worry about it........it’s only an hour out of your life.  I used to worry about my heated garage loosing heat.....if the boat is dry, no worries?
Be cautious on the electronic thermostat models as most if not all of them do not have a memory and if they loose power they do not turn back on and you could then freeze when you thought you were protected.  My trailer froze a couple of winters ago due to this.  The power flickered and reset the heater to off and the trailer froze some time after that.
gravity12    83
So lets say its late in the season and its gonna be close to or  feeezing. How effective would it be to just make sure you take your boat for a spin and get the motor hot. Would it hold enough heat that night to not freeze?
-HONCHO-    13
  • On 10/3/2017 at 1:45 PM, Cwazy1 said:
    As I mentioned in the other thread:
    If you're on a budget:
    http://amzn.to/2yWvaz2
    If you're willing to spend a bit more :
    http://amzn.to/2xfbiK6
    So if I'm understanding this correctly, you can simply throw one of these bad boys in your engine bay and skip the winterization portion of draining the block? The only thing you would have to do is blow out the heater core?
Hey Honcho, What exactly are you trying to figure out with all these winterizing questions? I wouldn't take any chances if you're up in Seattle. I'm way down in South Texas and this winter we had 2 freezes, both lasting 3-4 hours. My boat is kept indoors and all I do to winterize is hang a couple of 100w light bulbs in the engine bay and a couple of 500w halogen work lights outside pointing at the boat, hoping that the power doesn't fail. I think if I was in your neck of the woods I would take the proper steps to winterize. Do a little more digging on the site, I know there are some DIY'ers that did a few write ups on winterizing with pics and video.
What Rhunt said.
You're in a freezing climate, you're going to have to fully winterize your boat each year. In the Bay Area here in CA it dips below freezing maybe a handful of times a year and usually only a couple hours so its not a huge priority and I still winterize just for piece of mind.
The bigger question is, is your boat already winterized? Spring is in a month or so, your new to you boat should have been winterized back in October I would imagine.
-HONCHO-    13
Relax fellas, my boat was winterized back in September. The reason for the questions is I'm trying to get a feel for what tricks people do to winterize their boats, granted different regions of the country warrant different measures of course but I see a fair amount of people are from the Pacific Northwest. Ive heard of the lightbulb trick to keep mildew and mold to a minimum inside the cabin area but haven't heard of an engine bay heater as the sole insurance to not freezing up the block. And as far as the earlier antifreeze question, it was asked to me once so I passed it on for a more in depth response.
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
