beau t
rear seat redo
beau t    8
hey guys i have a 07 elite c4 and i would like to add a section into the rear seat to step on so the seat isn't taking the abuse. I'm looking for advice on what to do, any pics or how to's would also be great. Not sure i can take it to the upholstery shop and just say this is what i want? Any help would be appreciated!     Thanks Beau
Look at what they do on the new Nautique G23 back seat, basically they build a step using SeaDeck into the rear seat...and I am sure there is something under it to keep that area firm. Look genius to me.
Please share what you figure out cause I am getting my boat redone over winter and going to incorporate something similar to that myself, just not sure exactly how to make it work yet, was going to ask the vinyl guy for ideas....my thot was to cut out a 12x12 square of the foam and put some kind of hard rubber block in there, then install the vinyl and then install a piece of SeaDeck on the vinyl, directly over that rubber block. Don't know if that will work or not but it was my first idea.
I have a friend with a VLX, the back seats curve and go partially toward the middle, so the middle back seat is only about 24" wide. He removed the seat completely, cut a piece of HDPE the same size and put SeaDeck on it. Works perfect. I would do that except my back seat is much wider and I cannot lose that much seat.
beau t    8
also a winter project for me  if i come up with a good idea i will post, if you beat me to it also post because if your at lake norman thats not to far away i may come use your upholster !!! lol, guess i should update my sig I'm in SC
The newer boats have seadek under the rear corners and then you pull the seat up when people are getting in and out
I have that too and it is a great feature, but some people cannot go from the center walk-thru, down to the corners. I know my kids are not able to...that's why I want to add something to center of my back seat. Stitching is starting to come apart at that seam even tho we are careful not to step on it.
beau t    8
Mine is also coming apart at the seams from stepping on it and needs to be fixed while the foam is still in good shape. I have been searching and found some of the later boats have a 3 cushion seat, mine is 1 big seat if i were to cut it into 3 separates i would think this would be easier to work with? any opinions? Would there be a issue getting the seats to stay put while towing, i would think not, but these are questions of concern before getting to carried away.  i would think a upholstery shop could do it cheaper than buying factory but there is something about having factory fit parts thats appealing.         once again thanks for any input     Beau
Guess the question would be if you can create something where all 3 cushions stay in place on your boat. Guess one idea would be using the original base....making the middle SeaDeck and then have a cushion on either side. That way it all comes out in one piece and stay in place being factory base and you always have the center area for "walk thru". I may think about doing that option myself now that I think of it.
FYI...I used Boat Covers Unlimited in Moorseville, NC for my upholstery work. The do vinyl, custom covers and other misc work. Did a real nice job on my boat when I had them make my bow filler cushion. When I get the entire interior redone over winter, don't know who it will be since that will all go thru my dealer and I know he has his own guy for all vinyl work.
prorider17    30
I would go with what infinitysurf said. Basically, retain your 1 piece rear seat base, have it modified to have the center cut-out, and then run with GatorStep, SeaDek or AquaTraction. Now the question is how your rear sundeck could accommodate the same thing.
beau t    8
i haven't made it that far yet, the sun deck has a lot thinner padding so it dozen"t seem to be as badly affected but it might look a little funny with only 1 piece of GatorStep.  will keep investigating to see what i can rig up lol
Jlagos    23
That appears the be the simplest solution. You could also have a filler cushion made for the middle section that inserts over the step area for when your cruising around. Shouldn't be an overly expensive add on. You could add an accent color, centurion logo, or even CENTURION CREW emblem to the seat if you wanted!
      Love Spells That Work Fast ~Bring Back A Lost Love 24 Hours.Bring back a lost love 24 hours: love spell that work fast bringing back a lost love is very true. Why not restore your broken relationship if you still burning inside with same old love you had for each other this spell is designed to fix all your love issues.Stop acting though like you will heal your broken heart and cast a spell to bring back your lost love within 24 hours. This spell works no matter how long you have been parted ways with your partner. White magic love spells that work in the united kingdom Instant love spells to bring back your ex partner in the usa Marriage love spells that work for a good marriage Fastest love spells to reunite with your ex-lover Family reunion love spells that work in Chicago Voodoo obedience love spells that work in the USA Effective marriage love spells that work instantly Effective love spells that work for marriage. Lost Love Spells That Work Fast Call +27630236059 Powerful Love Spells For Lovers to bring there lost lovers Back in Zambia -Swaziland- Ohio -Nevada -Port Elizabeth, Love spells magic that will help you apprehend your relationship problems discover your soul mate and make them fall in love with you with the help of MAMA ZUNGU. shop your marriage from divorce & make your relationship more potent restoration believe troubles & misunderstandings between fanatics and get lower back lost lover in just 48 hrs. love spells to opposite a breakup & shop your dating. Mis placed love spells to get your ex misplaced lover lower back completely & carry lower back lost love.heal relationship troubles the usage of love spells to boom love among people. love spells to banish intimacy & communique troubles in your courting. love spells to make a person fall in love with you attract a brand new lover stop your associate from dishonest on you & love spells to save you a divorce.misplaced love spells to completely get your ex husband again or ex spouse lower back. lost love spells to completely get your ex boyfriend or ex female friend returned.love spells chants to bolster a courting. chant these spiritually endowed words & wipe away your dating & marriage troubles. love spells chants that will help you locate love; make someone fall in love with you & get your ex returned. love spells chant to heal dating & marriage problems. Powerful Lost Love Spells Call On +27630236059  Bring back lost lover USING MAGIC LOVE spells In Italy -UK -USA- Singapore- Oman -Bahrain -London- Ireland -wales -Austria, My bring back lost lover spells will connect you and your lover with binding love spells. Enabling you to resolve all the issues.If you met a special someone who had a big impact on your life but lost their love. Mama Zungu has lost lover spells to reunite you with love.Be blessed with the love of that special someone who left a mark in your life. If you want to taste the powerful love of a lost lover who made you fall deeply in love & you find yourself wanting more of their love after a breakup or divorce then my bring back lost love spells can be of assistance to your situation.b Maybe your ex-lover wants nothing to do with you again, bring back lost love spells will help them forgive you or each of you to forgive each other of past wrongs & make you fall back in love with each other & enable you to restart a successful love relationship. Return lost love spells,For those who can move on, for those who can’t seem to forget that special lover from the past, for those who want to reconnect with an ex-lover, for those who want that one person who understood them & loved them like noon else.        CALL/WHATSAPP; +27630236059
